GPIO in secure bootloader example in sdk v15.2
I am trying to toggle an LED in bootloader, adding nrf_gpio_cfg_output/write has no effect to the code. The code compiles without errors but doesnt seem to be executed. What config option am I missing?
Any pointers to this can be very helpful.
Thanks
chaitz
  • Are you even executing the bootloader? I'd start by adding a breakpoint to the bootloader to verify that you're actually executing it.
  • Yes, I have tried that already. The boot loader is executing and breakpoints can be added to other statements too.
  • Hmm that's wierd.
    Do you mind sharing your bootloader code?
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup bootloader_secure_ble main.c
     * @ingroup dfu_bootloader_api
     * @brief Bootloader project main file for secure DFU.
    #include <stdint.h>
    #include "boards.h"
    #include "nrf_mbr.h"
    #include "nrf_bootloader.h"
    #include "nrf_bootloader_app_start.h"
    #include "nrf_bootloader_dfu_timers.h"
    #include "nrf_dfu.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "app_error.h"
    #include "app_error_weak.h"
    #include "nrf_bootloader_info.h"
    #include "nrf_delay.h"
    static void on_error(void)
        NRF_LOG_FINAL_FLUSH();
    #if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
        // To allow the buffer to be flushed by the host.
        nrf_delay_ms(100);
    #ifdef NRF_DFU_DEBUG_VERSION
        NRF_BREAKPOINT_COND;
        NVIC_SystemReset();
    void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
        NRF_LOG_ERROR("%s:%d", p_file_name, line_num);
        on_error();
    void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
        NRF_LOG_ERROR("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x", id, pc, info);
        on_error();
    void app_error_handler_bare(uint32_t error_code)
        NRF_LOG_ERROR("Received an error: 0x%08x!", error_code);
        on_error();
     * @brief Function notifies certain events in DFU process.
    static void dfu_observer(nrf_dfu_evt_type_t evt_type)
        switch (evt_type)
            case NRF_DFU_EVT_DFU_FAILED:
            case NRF_DFU_EVT_DFU_ABORTED:
            case NRF_DFU_EVT_DFU_INITIALIZED:
                bsp_board_led_on(BSP_BOARD_LED_0);
                bsp_board_led_on(BSP_BOARD_LED_1);
                bsp_board_led_off(BSP_BOARD_LED_2);
            case NRF_DFU_EVT_TRANSPORT_ACTIVATED:
                bsp_board_led_off(BSP_BOARD_LED_1);
                bsp_board_led_on(BSP_BOARD_LED_2);
            case NRF_DFU_EVT_DFU_STARTED:
    /**@brief Function for application main entry. */
        uint32_t ret_val;
        // Protect MBR and bootloader code from being overwritten.
        ret_val = nrf_bootloader_flash_protect(0, MBR_SIZE, false);
        APP_ERROR_CHECK(ret_val);
        ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR, BOOTLOADER_SIZE, false);
        (void) NRF_LOG_INIT(nrf_bootloader_dfu_timer_counter_get);
        NRF_LOG_INFO("Inside main");
        nrf_gpio_cfg_output (11);
        nrf_gpio_pin_set (11);
        ret_val = nrf_bootloader_init(dfu_observer);
        // Either there was no DFU functionality enabled in this project or the DFU module detected
        // no ongoing DFU operation and found a valid main application.
        // Boot the main application.
        nrf_bootloader_app_start();
        // Should never be reached.
        NRF_LOG_INFO("After main");
    Just adding 2 lines to existing secure bootloader example file, to config pin 11 as output and set it, doesn't work (line 142, 143).
  • I need you to set a breakpoint on line 144 and read the GPIO registers called PIN_CNF[11] and OUTSET. If they are set correctly then the GPIO is working.
    Thanks for the response. Its all working now, I just figured out that there was another GPIO to be configured before setting pin 11. I obviously missed this in the schematic!! Apologies for this ticket, please this question. And many thanks for your time.
