HI nordic,
I had a NRF52832 DK which acts as central. In ble_app_uart_c example i need to scan the battery level of nearby beacons without connecting to the beacons
How can it be done.
Thank you
HI nordic,
How can it be done.
Thank you
If you're not connecting, it would have to be in the Advertising data - so you'd have to read it from there.
Battery level is in the services of the beacon
If you don't want to connect to the devices to optain the data(battery level), you need to put the data in the advertising or scan response packet.
Hi Sigurd
I had kept in the scan response packet.
#include <stdint.h>
#include <string.h>
#include "ble_advertising.h"
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_soc.h"
#include "nrf_drv_saadc.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_tps.h"
#include "ble_ias.h"
#include "ble_lls.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
#include "ble_conn_state.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "ble_ias_c.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble_db_discovery.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
//#include "nrf_ble_scan.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_fstorage.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEVICE_NAME "NORDIC"
#define APP_BLE_OBSERVER_PRIO 3
#define APP_BLE_CONN_CFG_TAG 1
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(120000)
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS)
#define SLAVE_LATENCY 0
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
#define APP_ADV_INTERVAL 40
#define APP_ADV_TIMEOUT_IN_SECONDS 80
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS)
#define APP_ADV_DURATION 18000
#define BLE_ADV_DIRECTED_ENABLED true
#define BLE_ADV_DIRECTED_DISABLED false
#define BLE_ADV_DIRECTED_SLOW_ENABLED true
#define BLE_ADV_DIRECTED_SLOW_DISABLED false
#define BLE_ADV_FAST_ENABLED true
#define BLE_ADV_FAST_DISABLED false
#define BLE_ADV_SLOW_ENABLED true
#define BLE_ADV_SLOW_DISABLED false
#define BLE_ADV_WHITELIST_ENABLED true
#define BLE_ADV_WHITELIST_DISABLED false
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT 3
#define SEC_PARAM_BOND 1
#define SEC_PARAM_MITM 0
#define SEC_PARAM_LESC 0
#define SEC_PARAM_KEYPRESS 0
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB 0
#define SEC_PARAM_MIN_KEY_SIZE 7
#define SEC_PARAM_MAX_KEY_SIZE 16
#define BLE_GAP_ADV_TYPE_ADV_IND 0x00
#define BLE_GAP_ADV_TYPE_ADV_DIRECT_IND 0x01
#define BLE_GAP_ADV_TYPE_ADV_SCAN_IND 0x02
#define BLE_GAP_ADV_TYPE_ADV_NONCONN_IND 0x03
#define BLE_GAP_ADDR_TYPE_PUBLIC 0x00
#define BLE_GAP_ADDR_TYPE_RANDOM_STATIC 0x01
#define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE 0x02
#define BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE 0x03
#define INITIAL_LLS_ALERT_LEVEL BLE_CHAR_ALERT_LEVEL_NO_ALERT
#define TX_POWER_LEVEL (-8)
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600
#define ADC_PRE_SCALING_COMPENSATION 6
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270
#define ADC_RES_10BIT 1024
#define DEAD_BEEF 0xDEADBEEF
#define APP_BEACON_INFO_LENGTH 0x17
#define APP_ADV_DATA_LENGTH 0x15
#define APP_DEVICE_TYPE 0x02
#define APP_MEASURED_RSSI 0xC5
#define APP_COMPANY_IDENTIFIER 0x004C
#define APP_MAJOR_VALUE 0x00, 0x02
#define APP_MINOR_VALUE 0x00, 0x02
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18
#define UICR_ADDRESS 0x10001080
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
APP_TIMER_DEF(m_battery_timer_id);
BLE_TPS_DEF(m_tps);
BLE_IAS_DEF(m_ias, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_LLS_DEF(m_lls);
BLE_BAS_DEF(m_bas);
BLE_IAS_C_DEF(m_ias_c);
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr);
BLE_ADVERTISING_DEF(m_advertising);
BLE_DB_DISCOVERY_DEF(m_ble_db_discovery);
static volatile bool m_is_high_alert_signalled;
static volatile bool m_is_ias_present = false;
static nrf_saadc_value_t adc_buf[2];
static ble_uuid_t m_adv_uuids[] =
{BLE_UUID_IMMEDIATE_ALERT_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_LINK_LOSS_SERVICE, BLE_UUID_TYPE_BLE}
static ble_gap_adv_params_t m_adv_params;
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static uint8_t m_enc_scandata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = m_enc_scandata,
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =
APP_DEVICE_TYPE,
APP_ADV_DATA_LENGTH,
APP_BEACON_UUID,
APP_MAJOR_VALUE,
APP_MINOR_VALUE,
APP_MEASURED_RSSI
static void on_ias_evt(ble_ias_t * p_ias, ble_ias_evt_t * p_evt);
static void on_lls_evt(ble_lls_t * p_lls, ble_lls_evt_t * p_evt);
static void on_ias_c_evt(ble_ias_c_t * p_lls, ble_ias_c_evt_t * p_evt);
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static void advertising_init(void);
static void advertising_start(bool erase_bonds);
static void service_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
nrf_saadc_value_t adc_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
uint32_t err_code;
adc_result = p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
DIODE_FWD_VOLT_DROP_MILLIVOLTS;
percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_ias_c_on_db_disc_evt(&m_ias_c, p_evt);
static void adc_configure(void)
ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
nrf_saadc_channel_config_t config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
ret_code_t err_code;
err_code = nrf_drv_saadc_sample();
static void timers_init(void)
err_code = app_timer_init();
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_KEYRING);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
break; // BLE_ADV_EVT_FAST
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
break; // BLE_ADV_EVT_IDLE
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_t scandata;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL;
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0;
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
memset(&scandata, 0, sizeof(scandata));
scandata.name_type = BLE_ADVDATA_FULL_NAME;
scandata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
scandata.uuids_complete.p_uuids = m_adv_uuids;
ble_gap_addr_t gap_address;
gap_address.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC;
memcpy(&gap_address.addr, "\xbb\xaa\xcc\xbb\xaa\xAC", sizeof(gap_address.addr));
err_code = sd_ble_gap_addr_set(&gap_address);
err_code = ble_advdata_encode(&scandata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
if (erase_bonds == true){
delete_bonds();
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
///**@brief Function for initializing the Advertising functionality.
// * @details Encodes the required advertising data and passes it to the stack.
// * Also builds a structure to be passed to the stack when starting advertising.
//static void advertising_init(void)
// ret_code_t err_code;
// ble_advertising_init_t init;
// memset(&init, 0, sizeof(init));
// init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
// init.advdata.include_appearance = true;
// init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
// init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
// init.advdata.uuids_complete.p_uuids = m_adv_uuids;
// init.config.ble_adv_fast_enabled = true;
// init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
// init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
// init.evt_handler = on_adv_evt;
// err_code = ble_advertising_init(&m_advertising, &init);
// APP_ERROR_CHECK(err_code);
// ble_advertising_conn_cfg_tag_set(&m_advertising, APP_BLE_CONN_CFG_TAG);
static void qwr_init(void)
nrf_ble_qwr_init_t qwr_init_obj = {0};
qwr_init_obj.error_handler = nrf_qwr_error_handler;
err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init_obj);
static void tps_init(void)
ble_tps_init_t tps_init_obj;
memset(&tps_init_obj, 0, sizeof(tps_init_obj));
tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL;
tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
err_code = ble_tps_init(&m_tps, &tps_init_obj);
static void ias_init(void)
ble_ias_init_t ias_init_obj;
memset(&ias_init_obj, 0, sizeof(ias_init_obj));
ias_init_obj.evt_handler = on_ias_evt;
ias_init_obj.alert_wr_sec = SEC_JUST_WORKS;
err_code = ble_ias_init(&m_ias, &ias_init_obj);
static void lls_init(void)
ble_lls_init_t lls_init_obj;
// Initialize Link Loss Service
memset(&lls_init_obj, 0, sizeof(lls_init_obj));
lls_init_obj.evt_handler = on_lls_evt;
lls_init_obj.error_handler = service_error_handler;
lls_init_obj.initial_alert_level = INITIAL_LLS_ALERT_LEVEL;
lls_init_obj.alert_level_rd_sec = SEC_JUST_WORKS;
lls_init_obj.alert_level_wr_sec = SEC_JUST_WORKS;
err_code = ble_lls_init(&m_lls, &lls_init_obj);
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = on_bas_evt;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_OPEN;
bas_init_obj.bl_cccd_wr_sec = SEC_OPEN;
bas_init_obj.bl_report_rd_sec = SEC_OPEN;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
static void ias_client_init(void)
ble_ias_c_init_t ias_c_init_obj;
memset(&ias_c_init_obj, 0, sizeof(ias_c_init_obj));
m_is_high_alert_signalled = false;
ias_c_init_obj.evt_handler = on_ias_c_evt;
ias_c_init_obj.error_handler = service_error_handler;
err_code = ble_ias_c_init(&m_ias_c, &ias_c_init_obj);
qwr_init();
tps_init();
ias_init();
lls_init();
bas_init();
ias_client_init();
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
static void alert_signal(uint8_t alert_level)
switch (alert_level)
case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
NRF_LOG_INFO("No Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
break; // BLE_CHAR_ALERT_LEVEL_NO_ALERT
case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
NRF_LOG_INFO("Mild Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
break; // BLE_CHAR_ALERT_LEVEL_MILD_ALERT
case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
NRF_LOG_INFO("HIGH Alert.");
err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
break; // BLE_CHAR_ALERT_LEVEL_HIGH_ALERT
switch (p_evt->evt_type)
case BLE_IAS_EVT_ALERT_LEVEL_UPDATED:
if (p_evt->p_link_ctx != NULL)
alert_signal(p_evt->p_link_ctx->alert_level);
break; // BLE_IAS_EVT_ALERT_LEVEL_UPDATED
// No implementation needed.
case BLE_LLS_EVT_LINK_LOSS_ALERT:
alert_signal(p_evt->params.alert_level);
break; // BLE_LLS_EVT_LINK_LOSS_ALERT
static void on_ias_c_evt(ble_ias_c_t * p_ias_c, ble_ias_c_evt_t * p_evt)
case BLE_IAS_C_EVT_DISCOVERY_COMPLETE:
// IAS is found on peer. The Find Me Locator functionality of this app will work.
err_code = ble_ias_c_handles_assign(&m_ias_c,
p_evt->conn_handle,
p_evt->alert_level.handle_value);
m_is_ias_present = true;
break; // BLE_IAS_C_EVT_DISCOVERY_COMPLETE
case BLE_IAS_C_EVT_DISCOVERY_FAILED:
// IAS is not found on peer. The Find Me Locator functionality of this app will NOT work.
break; // BLE_IAS_C_EVT_DISCOVERY_FAILED
case BLE_IAS_C_EVT_DISCONN_COMPLETE:
// Disable alert buttons
break; // BLE_IAS_C_EVT_DISCONN_COMPLETE
case BLE_BAS_EVT_NOTIFICATION_ENABLED:
// Start battery timer
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
case BLE_BAS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_battery_timer_id);
break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// Assign connection handle to the Queued Write module.
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr, p_ble_evt->evt.gap_evt.conn_handle);
// Discover peer's services.
err_code = ble_db_discovery_start(&m_ble_db_discovery,
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ias_c.conn_handle,
case BSP_EVENT_KEY_0:
if (m_is_ias_present)
if (!m_is_high_alert_signalled)
err_code =
ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_HIGH_ALERT);
err_code = ble_ias_c_send_alert_level(&m_ias_c, BLE_CHAR_ALERT_LEVEL_NO_ALERT);
if (err_code == NRF_SUCCESS)
m_is_high_alert_signalled = !m_is_high_alert_signalled;
else if (
(err_code != NRF_ERROR_RESOURCES)
(err_code != NRF_ERROR_NOT_FOUND)
} break;
case BSP_EVENT_KEY_1:
NRF_LOG_INFO("Alert Off.");
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
///**@brief Function for starting advertising.
//static void advertising_start(bool erase_bonds)
// if (erase_bonds == true){
// delete_bonds();
// // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
// else
// uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, TX_POWER_LEVEL);
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
adc_configure();
gap_params_init();
gatt_init();
advertising_init();
db_discovery_init();
services_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Proximity example started.");
advertising_start(erase_bonds);
tx_power_set();
// Enter main loop.
for (;;)
idle_state_handle();
So now using ble_app_uart_c example i need to read the battery level.
Please give any code if available
Thank you.
You could put the battery level into e.g. the manufacturer specific data field in the advertising/ scan-response packet.
Naralasetty Praneeth said:Please give any code if available
What SDK version are you using ?
