ESB - BLE uart timeslot problem - Timeslots stops being called
Hi
I have implemented (heavily base on the found examples) an application which uses both ESB and BLE.
For now I focus on developing the ESB part of the SW.
I am using the SDK 15.2.0 and developing for a NRF52832 using Segger.
The softdevice is the newest S132.
It actually works quite well, but my main problem is that my timeslot-interrups only occurs as long as the BLE is advertising or if there is an ongoing connection.
So the default advertisement timeout is 180 seconds, after this the interrupts-doesn't occur anymore.
I have found others with this problem, but either their solution is just to restart advertisement, or else they didn't write you back here at the forum.
https://devzone.nordicsemi.com/f/nordic-q-a/21458/sleep-mode-during-multiprotocol-timeslot-api
Sometimes I need to use ESB without using the BLE part.
In general I cannot find very much documentaion about how the ESB and BLE are related regarding the timeslots?
Hope you can help figure this out.
Best regards
Parents Reply
  • Hey I'm afraid I still can't compile.
    In frozen.c you've missed stdint.h, I get compile errors because int64_t and all other basic types are undefined. This is true for a lot of the source and header files.
    I do not understand how you can compile without the necessary standard libraries included in your compilation units, though I'm not that familiar with CPP and its preprocessor and compilation units.
    What version of Segger ES are you using?
