nrf52810: TWI interfacing with SHTW2 Humidity/Temperature Sensor
I am using a custom board with the nrf52810 and trying to interface with the SHTW2 sensor. The sensor has an I2C interface and hence I use the TWI peripheral for this. However, the transfer of data does not take place. Below is my read function:
void SHTW2_read(){
    uint8_t m_sample[2];
    uint8_t writeMode[] = {0x70};
    uint8_t readMode[] = {0x71};
    uint8_t reg[2] = {0x78, 0x66};
    ret_code_t err_code;
    //while (m_xfer_done == false);
    m_xfer_done = false;
    err_code = nrf_drv_twi_tx(&m_twi, SHTW2_ADDR, writeMode, sizeof(writeMode), true);
    nrf_delay_ms(5);
    err_code = nrf_drv_twi_tx(&m_twi, SHTW2_ADDR, reg, sizeof(reg), true);
    nrf_delay_ms(5);
    err_code = nrf_drv_twi_tx(&m_twi, SHTW2_ADDR, readMode, sizeof(readMode), true);
    err_code = nrf_drv_twi_rx(&m_twi, SHTW2_ADDR, m_sample, sizeof(m_sample));
    temperature = m_sample[0] << 8 | m_sample[1];
I am using the TWI sensor example as base for this, but the code gets stuck at the while loop waiting for the handler to be called where the flag m_xfer_done is set. The handler never gets called. Can anyone point me as to where I am going wrong? May be my fundamental understanding of TWI is wrong. Thanks for the help in advance.
    Thanks for the help. I do get a good waveform now with the acquisition tip you gave. Sample of the waveform is below:
    I was able to check on the waveform that I get and modify the code to get the required result. Basically I was sending a write command but this is already sent when I call nrf_drv_twi_tx. I got rid of that statement and send only the command for measurement and then read.
    Thanks again for the help.
