Enable/Disable BLE Stack and Softdevice -- SDK 15.3 S132
Have an application that configures a wifi SOC using spim before enabling BLE scanner.
When it is running there are 4 timer events running and the main loop check status and sends data using the wifi soc.
All that works fine until there is a socket error or other issue with the wifi soc.
In order to recover from those errors, you have to stop/start the soc well beyond what the softdevice can tolerate.
So I need to disable the softdevice and scanning and then reconfigure the wifi soc.
I use   ble_stack_stop();, nrf_drv_clock_lfclk_request(NULL);
to stop the softdevice and get the clock going again.
I had to re-init the spim interface but that worked out ok.
But the timer events are not being triggered. Do they need to be re-initialized as well ?
What is the best/correct way to temporarily disable the softdevice while  allowing the application with spim and app_timers to run as they were when the softdevice was enabled ?
This also allows for debugging functions after startup that don't require the softdevice by disabling it and then having full debug capability.
I used the GAZELL/BLE example and added a timer to switch between modes and that worked so I will have to re-visit how/why the timer continued to work in that application but not in my application.
So the key questions are:
1) Based on the use of spim and timer events, am I disabling the softdevice and stack right ?
2) What should be needed to get the spim interface and timers working other than the lfclk_request referenced above ?
3) Then what is needed to go back to the original environment with the softdevice and stack operational ?
