Provision Problem with mesh
I have 3 boards(1-board is configured with 2 client instance and 2 sever instance acting as control model for own model) (2 - board configured as client and server (control Model) without instance) and 3rd board also configured as same as second board. While i configure 3rd board  it merge with 2nd board configuration. I attached log for your clarification. Please help me.
<t: 0>, main.c, 601, ----- BLE Mesh Custom Provisioner Demo -----
<t: 0>, mesh_softdevice_init.c, 117, Initializing SoftDevice...
<t: 0>, mesh_softdevice_init.c, 75, Enabling BLE...
<t: 16>, mesh_softdevice_init.c, 109, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
<t: 598>, main.c, 539, Initializing and adding models
<t: 609>, main.c, 582, Setup defaults: Adding keys, addresses, and bindings
<t: 755>, provisioner_helper.c, 329, netkey_handle: 0
<t: 767>, main.c, 631, <start>
<t: 1079>, main.c, 120, Flash write complete
<t: 1081>, main.c, 618, Starting application ...
<t: 1084>, main.c, 620, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
<t: 1088>, main.c, 621, Dev key : 048A02F667DB79C81D370B2443764C91
<t: 1091>, main.c, 622, Net key : B4EF7988FA9A0DCB3212F639D83D14A8
<t: 1094>, main.c, 623, App key : 912CC77A9A4D27B1BD1990E658283BC8
<t: 1097>, main.c, 624, Press Button 1 to start provisioning and configuration process.
<t: 288021>, main.c, 499, Button 1 pressed
<t: 288023>, main.c, 385, Waiting for Client - Server node_0 to be provisioned ...
<t: 292768>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
<t: 338909>, provisioner_helper.c, 144, UUID seen: 0059000000000000975B2B98BE9A8FF2
<t: 338912>, provisioner_helper.c, 95, UUID filter matched
<t: 339654>, provisioner_helper.c, 259, Provisioning link established
<t: 352457>, provisioner_helper.c, 254, Static authentication data provided
<t: 364391>, provisioner_helper.c, 192, Provisioning completed received
<t: 364394>, provisioner_helper.c, 197, Adding device address, and device keys
<t: 364399>, provisioner_helper.c, 214, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 3
<t: 368656>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
<t: 368660>, main.c, 306, Provisioning successful
<t: 368663>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0100 elements: 8
<t: 368666>, node_setup.c, 1087, Configuring Node: 0x0100
<t: 368669>, node_setup.c, 1001, Config client setup: devkey_handle:3 addr_handle:0
<t: 368673>, node_setup.c, 445, Getting composition data
<t: 368714>, main.c, 120, Flash write complete
<t: 372490>, main.c, 356, Config client event
<t: 372492>, node_setup.c, 455, Adding appkey
<t: 376158>, main.c, 356, Config client event
<t: 376160>, node_setup.c, 350, opcode status field: 0
<t: 376163>, node_setup.c, 466, App key bind: Health server
<t: 376165>, config_client.c, 840, Client model app bind
<t: 376168>, config_client.c, 372, Element Address_app_bind: 0x0100
<t: 376170>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 377156>, main.c, 356, Config client event
<t: 377158>, node_setup.c, 350, opcode status field: 0
<t: 377161>, node_setup.c, 740, Setting publication address for the health server to 0x0001
<t: 380536>, main.c, 356, Config client event
<t: 380538>, node_setup.c, 350, opcode status field: 0
<t: 380541>, node_setup.c, 540, App key bind_c0: Custom client on element 0x0101
<t: 380544>, node_setup.c, 545, App key bind_c0: Custom client on element 0x0101
<t: 380547>, config_client.c, 840, Client model app bind
<t: 380549>, config_client.c, 372, Element Address_app_bind: 0x0101
<t: 380552>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 382206>, main.c, 356, Config client event
<t: 382208>, node_setup.c, 350, opcode status field: 0
<t: 382211>, node_setup.c, 540, App key bind_c0: Custom client on element 0x0102
<t: 382214>, node_setup.c, 545, App key bind_c0: Custom client on element 0x0102
<t: 382217>, config_client.c, 840, Client model app bind
<t: 382220>, config_client.c, 372, Element Address_app_bind: 0x0102
<t: 382222>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 382904>, main.c, 356, Config client event
<t: 382906>, node_setup.c, 350, opcode status field: 0
<t: 382909>, node_setup.c, 615, Client publication_c0
<t: 382911>, node_setup.c, 618, Element Address_client_publication_c0: 0x0101
<t: 382914>, node_setup.c, 622, appkey index for client publication_c0: 0x0000
<t: 382917>, node_setup.c, 625, TTL for client publication_c0: 0x001E
<t: 382920>, node_setup.c, 633, Set: custom client-c0: 0x0101 pub addr: 0x0109
<t: 385943>, main.c, 356, Config client event
<t: 385946>, node_setup.c, 350, opcode status field: 0
<t: 385948>, node_setup.c, 643, Client publication_c0_1
<t: 385950>, node_setup.c, 646, Element Address_client_publication_c0_1: 0x0102
<t: 385954>, node_setup.c, 650, appkey index for client publication_c0_1: 0x0000
<t: 385957>, node_setup.c, 653, TTL for client publication_c0_1: 0x001E
<t: 385959>, node_setup.c, 661, Set: custom client-c0_1: 0x0102 pub addr: 0x010C
<t: 390181>, main.c, 356, Config client event
<t: 390184>, node_setup.c, 350, opcode status field: 0
<t: 390186>, node_setup.c, 485, App key bind for cm_0: Custom server
<t: 390189>, node_setup.c, 490, App key bind_server_0: Custom Server on element 0x0103
<t: 390192>, config_client.c, 840, Client model app bind
<t: 390194>, config_client.c, 372, Element Address_app_bind: 0x0103
<t: 390197>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 392000>, main.c, 356, Config client event
<t: 392003>, node_setup.c, 350, opcode status field: 0
<t: 392005>, node_setup.c, 485, App key bind for cm_0: Custom server
<t: 392008>, node_setup.c, 490, App key bind_server_0: Custom Server on element 0x0104
<t: 392011>, config_client.c, 840, Client model app bind
<t: 392013>, config_client.c, 372, Element Address_app_bind: 0x0104
<t: 392016>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 392917>, main.c, 356, Config client event
<t: 392919>, node_setup.c, 350, opcode status field: 0
<t: 392922>, node_setup.c, 774, Server publication_c0
<t: 392924>, node_setup.c, 777, server node addr element 0x0103
<t: 392927>, node_setup.c, 781, appkey index for server publication_c0: 0x0000
<t: 392930>, node_setup.c, 784, TTL for server publication_c0: 0x001E
<t: 392933>, node_setup.c, 791, Set: custom server_c0 pub addr_c: 0x0108
<t: 396294>, main.c, 356, Config client event
<t: 396296>, node_setup.c, 350, opcode status field: 0
<t: 396298>, node_setup.c, 801, Server publication_c0_1
<t: 396301>, node_setup.c, 804, server node addr element 0x0104
<t: 396303>, node_setup.c, 808, appkey index for server publication_c0_1: 0x0000
<t: 396306>, node_setup.c, 811, TTL for server publication_c0_1: 0x001E
<t: 396309>, node_setup.c, 818, Set: custom server_c0_1 pub addr_c: 0x0109
<t: 400458>, main.c, 356, Config client event
<t: 400461>, node_setup.c, 350, opcode status field: 0
<t: 400463>, main.c, 251, Configuration of device 0 successful
<t: 400466>, main.c, 263, Waiting for Client - Server node_1 to be provisioned ...
<t: 400470>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
<t: 400472>, main.c, 291, All servers provisioned
<t: 400507>, main.c, 120, Flash write complete
<t: 4522528>, provisioner_helper.c, 144, UUID seen: 0059000000000000A46956D7E9F77D64
<t: 4522531>, provisioner_helper.c, 95, UUID filter matched
<t: 4522986>, provisioner_helper.c, 259, Provisioning link established
<t: 4536557>, provisioner_helper.c, 254, Static authentication data provided
<t: 4548856>, provisioner_helper.c, 192, Provisioning completed received
<t: 4548859>, provisioner_helper.c, 197, Adding device address, and device keys
<t: 4548864>, provisioner_helper.c, 214, Addr: 0x0108 addr_handle: 1 netkey_handle: 0 devkey_handle: 4
<t: 4552882>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
<t: 4552886>, main.c, 306, Provisioning successful
<t: 4552888>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x0108 elements: 3
<t: 4552892>, node_setup.c, 1087, Configuring Node: 0x0108
<t: 4552895>, node_setup.c, 1001, Config client setup: devkey_handle:4 addr_handle:1
<t: 4552899>, node_setup.c, 445, Getting composition data
<t: 4552940>, main.c, 120, Flash write complete
<t: 4555082>, main.c, 356, Config client event
<t: 4555086>, node_setup.c, 455, Adding appkey
<t: 4559209>, main.c, 356, Config client event
<t: 4559211>, node_setup.c, 350, opcode status field: 0
<t: 4559213>, node_setup.c, 466, App key bind: Health server
<t: 4559216>, config_client.c, 840, Client model app bind
<t: 4559218>, config_client.c, 372, Element Address_app_bind: 0x0108
<t: 4559221>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 4560639>, main.c, 356, Config client event
<t: 4560641>, node_setup.c, 350, opcode status field: 0
<t: 4560644>, node_setup.c, 740, Setting publication address for the health server to 0x0001
<t: 4563809>, main.c, 356, Config client event
<t: 4563811>, node_setup.c, 350, opcode status field: 0
<t: 4563814>, node_setup.c, 564, App key bind_if_loop_c1: client on element 0x0108
<t: 4563817>, node_setup.c, 566, App key bind_c1: Custom client on element 0x0108
<t: 4563820>, node_setup.c, 571, App key bind_c1: Custom client on element 0x0108
<t: 4563823>, config_client.c, 840, Client model app bind
<t: 4563826>, config_client.c, 372, Element Address_app_bind: 0x0108
<t: 4563829>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 4565160>, main.c, 356, Config client event
<t: 4565162>, node_setup.c, 350, opcode status field: 0
<t: 4565164>, node_setup.c, 671, Client publication_c1
<t: 4565167>, node_setup.c, 674, Element Address_client_publication_c1: 0x0108
<t: 4565170>, node_setup.c, 678, appkey index for client publication: 0x0000
<t: 4565173>, node_setup.c, 681, TTL for client publication: 0x001E
<t: 4565175>, node_setup.c, 689, Set: custom client-c1: 0x0108 pub addr: 0x0103
<t: 4568425>, main.c, 356, Config client event
<t: 4568428>, node_setup.c, 350, opcode status field: 0
<t: 4568430>, node_setup.c, 506, App key bind for cm_1: Custom server
<t: 4568433>, node_setup.c, 511, App key bind_server_1: Custom Server on element 0x0109
<t: 4568436>, config_client.c, 840, Client model app bind
<t: 4568439>, config_client.c, 372, Element Address_app_bind: 0x0109
<t: 4568441>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 4569978>, main.c, 356, Config client event
<t: 4569980>, node_setup.c, 350, opcode status field: 0
<t: 4569982>, node_setup.c, 828, Server publication_c1
<t: 4569985>, node_setup.c, 831, server node addr element 0x0109
<t: 4569987>, node_setup.c, 835, appkey index for server publication_c1: 0x0000
<t: 4569990>, node_setup.c, 838, TTL for server publication_c1: 0x001E
<t: 4569993>, node_setup.c, 845, Set: custom server pub addr_c1: 0x0101
<t: 4573028>, main.c, 356, Config client event
<t: 4573030>, node_setup.c, 350, opcode status field: 0
<t: 4573032>, main.c, 251, Configuration of device 1 successful
<t: 4573035>, main.c, 274, Waiting for Client - Server node_2 to be provisioned ...
<t: 4573038>, provisioner_helper.c, 282, Scanning For Unprovisioned Devices
<t: 4573078>, main.c, 120, Flash write complete
<t: 4966915>, provisioner_helper.c, 144, UUID seen: 0059000000000000F8EF344689E9F6C7
<t: 4966918>, provisioner_helper.c, 95, UUID filter matched
<t: 4967383>, provisioner_helper.c, 259, Provisioning link established
<t: 4980955>, provisioner_helper.c, 254, Static authentication data provided
<t: 4993329>, provisioner_helper.c, 192, Provisioning completed received
<t: 4993332>, provisioner_helper.c, 197, Adding device address, and device keys
<t: 4993338>, provisioner_helper.c, 214, Addr: 0x010B addr_handle: 2 netkey_handle: 0 devkey_handle: 5
<t: 4997030>, provisioner_helper.c, 155, Local provisioning link closed: prov_state: 2 remaining retries: 2
<t: 4997034>, main.c, 306, Provisioning successful
<t: 4997037>, provisioner_helper.c, 181, Provisioning complete. Node addr: 0x010B elements: 3
<t: 4997040>, node_setup.c, 1087, Configuring Node: 0x010B
<t: 4997043>, node_setup.c, 1001, Config client setup: devkey_handle:5 addr_handle:2
<t: 4997047>, node_setup.c, 445, Getting composition data
<t: 4997088>, main.c, 120, Flash write complete
<t: 4999108>, main.c, 356, Config client event
<t: 4999111>, node_setup.c, 455, Adding appkey
<t: 5002626>, main.c, 356, Config client event
<t: 5002628>, node_setup.c, 350, opcode status field: 0
<t: 5002630>, node_setup.c, 466, App key bind: Health server
<t: 5002633>, config_client.c, 840, Client model app bind
<t: 5002635>, config_client.c, 372, Element Address_app_bind: 0x010B
<t: 5002638>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 5003613>, main.c, 356, Config client event
<t: 5003615>, node_setup.c, 350, opcode status field: 0
<t: 5003618>, node_setup.c, 740, Setting publication address for the health server to 0x0001
<t: 5007362>, main.c, 356, Config client event
<t: 5007364>, node_setup.c, 350, opcode status field: 0
<t: 5007367>, node_setup.c, 566, App key bind_c1: Custom client on element 0x0108
<t: 5007370>, node_setup.c, 571, App key bind_c1: Custom client on element 0x0108
<t: 5007373>, config_client.c, 840, Client model app bind
<t: 5007375>, config_client.c, 372, Element Address_app_bind: 0x0108
<t: 5007378>, config_client.c, 374, Appkey Index_app_bind: 0x0000
<t: 5009005>, main.c, 356, Config client event
<t: 5009008>, node_setup.c, 350, opcode status field: 1
<t: 5009010>, main.c, 299, Configuration of device 2 failed. Press Button 1 to retry.
