#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "boards.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "ble_conn_state.h"
#include "app_error.h"
#include "app_timer.h"
#include "task_manager.h"
#include "nrf_cli.h"
#include "nrf_cli_rtt.h"
#include "nrf_cli_uart.h"
#include "nrf_cli_ble_uart.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "nrf_stack_guard.h"
#include "nrf_fstorage_sd.h"
#include "nrf_ble_scan.h"
#include "ble_db_discovery.h"
#include "ble_nus.h"
#include "ble_cus.h"
//#include "ble_hts.h"
#include "ble_conn_params.h"
#include "flash_write.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_log_backend_flash.h"
#define DEVICE_NAME "Nordic_CLI" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE 20 /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE 10 /**< Maximum number of events in the scheduler queue. */
#ifdef RK_CLI
#define ADDR_STRING_LEN (2 * (BLE_GAP_ADDR_LEN)+6)
#define BLE_UUID_NUS_SERVICE 0x0001 /**< The UUID of the Nordic UART Service. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
NRF_BLE_SCAN_DEF(m_scan);
#define N_AD_TYPES 4
#define UUID128_SIZE 16 /**< Size of 128 bit UUID. */
#define UUID16_SIZE 2
#define APP_SCHED_EVENT_HEADER_SIZE 8 /**< Size of app_scheduler.event_header_t (only for use inside APP_SCHED_BUF_SIZE()). */
/**@brief Compute number of bytes required to hold the scheduler buffer.
* @param[in] EVENT_SIZE Maximum size of events to be passed through the scheduler.
* @param[in] QUEUE_SIZE Number of entries in scheduler queue (i.e. the maximum number of events
* that can be scheduled for execution).
* @return Required scheduler buffer size (in bytes).
#define APP_SCHED_BUF_SIZE(EVENT_SIZE, QUEUE_SIZE) \
(((EVENT_SIZE) + APP_SCHED_EVENT_HEADER_SIZE) * ((QUEUE_SIZE) + 1))
/**@brief Scheduler event handler type. */
typedef void (*app_sched_event_handler_t)(void * p_event_data, uint16_t event_size);
/**@brief Macro for initializing the event scheduler.
* @details It will also handle dimensioning and allocation of the memory buffer required by the
* scheduler, making sure the buffer is correctly aligned.
* @note Since this macro allocates a buffer, it must only be called once (it is OK to call it
* several times as long as it is from the same location, e.g. to do a reinitialization).
#define APP_SCHED_INIT(EVENT_SIZE, QUEUE_SIZE) \
do \
static uint32_t APP_SCHED_BUF[CEIL_DIV(APP_SCHED_BUF_SIZE((EVENT_SIZE), (QUEUE_SIZE)), \
sizeof(uint32_t))]; \
uint32_t ERR_CODE = app_sched_init((EVENT_SIZE), (QUEUE_SIZE), APP_SCHED_BUF); \
APP_ERROR_CHECK(ERR_CODE); \
} while (0)
/**@brief Function for executing all scheduled events.
* @details This function must be called from within the main loop. It will execute all events
* scheduled since the last time it was called.
void app_sched_execute(void);
/**@brief Function for scheduling an event.
* @details Puts an event into the event queue.
* @param[in] p_event_data Pointer to event data to be scheduled.
* @param[in] event_size Size of event data to be scheduled.
* @param[in] handler Event handler to receive the event.
* @return NRF_SUCCESS on success, otherwise an error code.
uint32_t app_sched_event_put(void const * p_event_data,
uint16_t event_size,
app_sched_event_handler_t handler);
/**Buffer queue access macros
/** Initialization of buffer list */
#define BUFFER_LIST_INIT() \
do \
buffer_list.rp = 0; \
buffer_list.wp = 0; \
buffer_list.count = 0; \
} while (0)
/** Provide status of data list is full or not */
#define BUFFER_LIST_FULL() \
((MAX_BUFFER_ENTRIES == buffer_list.count - 1) ? true : false)
/** Provides status of buffer list is empty or not */
#define BUFFER_LIST_EMPTY() \
((0 == buffer_list.count) ? true : false)
#define BUFFER_ELEMENT_INIT(i) \
do \
buffer_list.buffer[(i)].p_data = NULL; \
} while (0)
//Tabs end
typedef struct
bool is_not_empty; /**< Indicates that the structure is not empty. */
uint8_t addr[BLE_GAP_ADDR_LEN]; /**< Device address. */
char dev_name[DEVICE_NAME_MAX_SIZE]; /**< Device name. */
int8_t RSSI_value_RK;
uint8_t uuid_buffer_1[UUID128_SIZE]; /**< Buffer for storing an UUID128. */
uint16_t uuid_len;
uint8_t uuid_type;
}scanned_device_t;
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
scanned_device_t m_device[DEVICE_TO_FIND_MAX]; /**< Stores device info from scan data. */
scanned_device_t * scan_device_info_get(void)
return m_device;
void scan_device_info_clear(void)
memset(m_device, 0, sizeof(m_device));
static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report);
void scan_start(void);
void int_addr_to_hex_str(char * p_result, uint8_t result_len, uint8_t const * const p_addr);
#define RSSI_THRESHOLD -80
static void adv_list_timer_handle(void * p_context);
static bool m_scanning = false; /**< Variable that informs about the ongoing scanning. True when scan is ON. */
#define FOUND_DEVICE_REFRESH_TIME APP_TIMER_TICKS(SCAN_LIST_REFRESH_INTERVAL) /**< Time after which the device list is clean and refreshed. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< Database discovery module instances. */
#define CENTRAL_SCANNING_LED BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1
static void db_discovery_init(void);
static void db_disc_handler(ble_db_discovery_evt_t * p_evt);
//extern ble_nus_t m_nus;
void ble_serv_on_db_disc_evt(ble_db_discovery_evt_t const * p_evt);
//static bool device_uuid_search(ble_gap_evt_adv_report_t const * p_adv_report);
void print_uuid(char * p_result, uint8_t result_len, uint8_t const * const p_uuid, uint8_t size);
typedef struct
uint32_t addr[BLE_GAP_ADDR_LEN]; /**< Device address. */
uint16_t uuid;
}known_list_t; __ALIGN(4)
#define MAX_DEVICE 8
extern known_list_t k_device[MAX_DEVICE];__ALIGN(4)
known_list_t temp_device;
//static bool service_flag = false;
extern uint8_t k_count = 0;
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_TIMEOUT 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define SCAN_REQUEST 0 /**< Active scannin is not set. */
#define SCAN_WHITELIST_ONLY 0 /**< We will not ignore unknown devices. */
static const ble_gap_scan_params_t m_scan_param =
.extended = 1,
.report_incomplete_evts = 1,
.active = SCAN_REQUEST,
.filter_policy = SCAN_WHITELIST_ONLY,
.scan_phys = NULL,
.interval = (uint16_t)SCAN_INTERVAL,
.window = (uint16_t)SCAN_WINDOW,
.timeout = SCAN_TIMEOUT
static const ble_gap_conn_params_t m_connection_param =
(uint16_t)MIN_CONN_INTERVAL,
(uint16_t)MAX_CONN_INTERVAL,
(uint16_t)SLAVE_LATENCY,
(uint16_t)CONN_SUP_TIMEOUT
//Added custom service
#define NOTIFICATION_INTERVAL APP_TIMER_TICKS(1000)
static void on_cus_evt(ble_cus_t * p_cus_service, ble_cus_evt_t * p_evt);
BLE_CUS_DEF(m_cus);
APP_TIMER_DEF(m_notification_timer_id);
ble_cus_init_t cus_init;
static ble_uuid_t const m_scan_uuid[] = {{BLE_UUID_NUS_SERVICE,0x03},
{BLE_UUID_HEALTH_THERMOMETER_SERVICE,BLE_UUID_TYPE_BLE},
{BLE_UUID_NONIN_SENSOR_SERVICE,BLE_UUID_TYPE_VENDOR_BEGIN}};
static void connect_to_target(ble_gap_evt_adv_report_t const * p_adv_report);
static bool connect = false;
static void conn_params_init(void);
static void conn_params_error_handler(uint32_t nrf_error);
static void on_conn_params_evt(ble_conn_params_evt_t * p_evt);
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
NRF_CLI_UART_DEF(cli_uart,0 , 256, 16);
NRF_CLI_BLE_UART_DEF(cli_ble_uart, &m_gatt, 64, 32);
NRF_CLI_DEF(m_cli_uart, "uart_cli:~$ ", &cli_uart.transport,'\r', 4);
NRF_CLI_DEF(m_ble_cli, "ble_cli:~$ ", &cli_ble_uart.transport,'\r', 8);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
task_id_t m_ble_console_task_id;
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_NUS_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE},
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
//If device is in scanning mode don't advertise
advertising_start(false);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
* @details Initialize the Heart Rate, Battery and Device Information services.
ble_dis_init_t dis_init;
// ble_hts_init_t hts_init;
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
dis_init.dis_char_rd_sec = SEC_OPEN;
err_code = ble_dis_init(&dis_init);
/* RK code to initialize the nonin services used by the application.*/
ble_uuid_t ble_uuid;
BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_HEALTH_THERMOMETER_SERVICE);
err_code = ble_db_discovery_evt_register(&ble_uuid);
if (err_code == NRF_SUCCESS)
if(err_code == NRF_ERROR_NULL)
NRF_LOG_INFO("error null pointer supplied\n\r");
if(err_code == NRF_ERROR_INVALID_STATE)
NRF_LOG_INFO("error NRF_ERROR_INVALID_STATE\n\r");
if(err_code == NRF_ERROR_NO_MEM)
NRF_LOG_INFO("error NRF_ERROR_NO_MEM\n\r");
// Add Nonin Oxy sensor Service UUID BASE
ble_uuid128_t base_uuid = BLE_UUID_NONIN_SENSOR_SERVICE_BASE;
// Initialize CUS Service init structure to zero.
memset(&cus_init, 0, sizeof(cus_init));
cus_init.evt_handler = on_cus_evt;
if (&m_cus == NULL || &cus_init == NULL)
NRF_LOG_INFO("NRF_ERROR_NULL");
// Initialize service structure
m_cus.evt_handler = cus_init.evt_handler;
m_cus.conn_handle = BLE_CONN_HANDLE_INVALID;
err_code = sd_ble_uuid_vs_add(&base_uuid, &m_cus.uuid_type);
if (err_code == NRF_ERROR_INVALID_ADDR)
NRF_LOG_INFO("error = NRF_ERROR_INVALID_ADDR\n\r");
if (err_code == NRF_ERROR_NO_MEM)
NRF_LOG_INFO("error = NRF_ERROR_NO_MEM\n\r");
ble_uuid.uuid = BLE_UUID_NONIN_SENSOR_SERVICE;
ble_uuid.type = m_cus.uuid_type;
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
//NRF_LOG_RAW_INFO("Fast advertising.\r");
case BLE_ADV_EVT_IDLE:
nrf_pwr_mgmt_run();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// For readability
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
#ifdef RK_CLI
case BLE_GAP_EVT_ADV_REPORT:
//bool res = device_uuid_search(&p_gap_evt->params.adv_report);
device_to_list_add(&p_gap_evt->params.adv_report);
} break;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
nrf_cli_ble_uart_config_t config = { .conn_handle = m_conn_handle };
err_code = nrf_cli_init(&m_ble_cli, &config, true, true, NRF_LOG_SEVERITY_INFO);
APP_ERROR_CHECK(nrf_cli_task_create(&m_ble_cli));
NRF_LOG_INFO("error code after connection = %d\n", err_code);
// err_code = sd_ble_gattc_primary_services_discover(conn_handle,0x0001,NULL);
do
err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
p_gap_evt->conn_handle);
NRF_LOG_INFO("discovery started :busy staus\n");
// NRF_LOG_INFO("service uuid found = %d\n\r", m_db_disc[p_gap_evt->conn_handle].srv_count );
}while(err_code == NRF_ERROR_BUSY);
// Update LEDs status and check whether it is needed to look for more
// peripherals to connect to.
bsp_board_led_on(CENTRAL_CONNECTED_LED);
if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
bsp_board_led_off(CENTRAL_SCANNING_LED);
// Resume scanning.
bsp_board_led_on(CENTRAL_SCANNING_LED);
scan_start();
} break;
connect = false;
NRF_LOG_INFO("Disconnected, reason %d.",
p_ble_evt->evt.gap_evt.params.disconnected.reason);
(void)nrf_cli_uninit(&m_ble_cli);
if (ble_conn_state_central_conn_count() == 0)
// Turn off the LED that indicates the connection.
bsp_board_led_off(CENTRAL_CONNECTED_LED);
// Start scanning.
if (m_scanning)
scan_start();
// Turn on the LED for indicating scanning.
}break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle,
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
#ifdef RK_CLI
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// For readability.
ble_gap_addr_t const * p_addr = &p_adv_report->peer_addr;
scan_evt_t scan_evt;
nrf_ble_scan_stop();
// NRF_LOG_INFO("addr = %x %x %x\n\r",p_addr->addr[0], p_addr->addr[1], p_addr->addr[5] );
memset(&scan_evt, 0, sizeof(scan_evt));
// Establish connection.
err_code = sd_ble_gap_connect(p_addr,
&m_scan_param,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
connect = true;
else if(err_code == NRF_ERROR_INVALID_ADDR)
NRF_LOG_INFO("NRF_ERROR_INVALID_ADDR failed\n\r");
else if(err_code == NRF_ERROR_INVALID_PARAM)
NRF_LOG_INFO("NRF_ERROR_INVALID_PARAM failed\n\r");
else if(err_code == NRF_ERROR_NOT_FOUND)
NRF_LOG_INFO("NRF_ERROR_NOT_FOUND failed\n\r");
else if (err_code == NRF_ERROR_INVALID_STATE)
NRF_LOG_INFO("NRF_ERROR_INVALID_STATE failed\n\r");
else if (err_code == BLE_ERROR_GAP_INVALID_BLE_ADDR)
NRF_LOG_INFO("BLE_ERROR_GAP_INVALID_BLE_ADDR failed\n\r");
else if (err_code == NRF_ERROR_CONN_COUNT)
// NRF_LOG_INFO("NRF_ERROR_CONN_COUNT failed\n\r");
else if (err_code == NRF_ERROR_RESOURCES)
NRF_LOG_INFO("NRF_ERROR_RESOURCES failed\n\r");
else if (err_code == NRF_ERROR_NOT_SUPPORTED)
NRF_LOG_INFO("NRF_ERROR_NOT_SUPPORTED failed\n\r");
scan_evt.scan_evt_id = NRF_BLE_SCAN_EVT_CONNECTING_ERROR;
scan_evt.params.connecting_err.err_code = err_code;
NRF_LOG_DEBUG("Connection status: %d", err_code);
nrf_ble_scan_start(&m_scan);
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_cus_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
switch(p_evt->evt_type)
case BLE_CUS_EVT_NOTIFICATION_ENABLED:
err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
case BLE_CUS_EVT_NOTIFICATION_DISABLED:
// Stop the application timer that is triggering the notifications
err_code = app_timer_stop(m_notification_timer_id);
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
case BLE_CUS_EVT_SERVO_CTR_VALUE_RECEIVED:
for (uint8_t i =0; i < sizeof(m_scan_uuid)/sizeof(m_scan_uuid[0]); i++)
// if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE &&
// p_evt->params.discovered_db.srv_uuid.uuid == m_scan_uuid[i].uuid)
p_evt->params.discovered_db.srv_uuid.uuid == m_scan_uuid[i].uuid &&
p_evt->params.discovered_db.srv_uuid.type == m_scan_uuid[i].type)
NRF_LOG_INFO("Service available:%x \n\r", p_evt->params.discovered_db.srv_uuid.uuid);
// service_flag = true;
// move device to known device list - copy MAC ID and UUID
if (k_count < DEVICE_TO_FIND_MAX)
for (uint8_t i = 0; i < k_count; i++)
if (memcmp(temp_device.addr,k_device[i].addr,sizeof(temp_device.addr)) == 0)
return;
memcpy(k_device[k_count].addr, temp_device.addr, sizeof(temp_device.addr));
memcpy(&k_device[k_count].RSSI_value_RK, &temp_device.RSSI_value_RK,sizeof(temp_device.RSSI_value_RK));
k_device[k_count].uuid = p_evt->params.discovered_db.srv_uuid.uuid;
k_count++;
if (connect == true)
err_code = sd_ble_gap_disconnect(m_conn_handle,BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
connect = false;
NRF_LOG_INFO("Disconnected after discovery\n\r");
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
ble_serv_on_db_disc_evt( p_evt);
/** @brief Database discovery initialization.
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
bool is_scanning(void)
return m_scanning;
/**@brief Function for handling the adv_list_timer event, which refreshes the connectable devices.
if (is_scanning())
scan_device_info_clear();
#if 0
uint8_t idx = 0;
uint16_t dev_name_offset = 0;
uint16_t field_len;
data_t adv_data;
int8_t peripheral_rssi = p_adv_report->rssi;
// Initialize advertisement report for parsing
adv_data.p_data = (uint8_t *)p_adv_report->data.p_data;
adv_data.data_len = p_adv_report->data.len;
for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
// If address is duplicated(already in the list), then return.
if (memcmp(p_adv_report->peer_addr.addr,
m_device[idx].addr,
sizeof(p_adv_report->peer_addr.addr)) == 0)
/* store rssi value */
memcpy(&m_device[idx].RSSI_value_RK,
&p_adv_report->rssi,
sizeof(p_adv_report->rssi));
return true;
// Device is not in the list.
for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
if (!m_device[idx].is_not_empty && (peripheral_rssi > RSSI_THRESHOLD)) // We find an empty entry in the list
uint16_t data_offset = 0;
uint8_t ad_types[N_AD_TYPES];
uint8_t * p_parsed_uuid;
uint16_t parsed_uuid_len = adv_data.data_len;
uint8_t uuid_type;
uint8_t raw_uuid_len;
ad_types[0] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE;
ad_types[1] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE;
ad_types[2] = BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE;
ad_types[3] = BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE;
for (uint8_t i = 0; (i < N_AD_TYPES) && (data_offset == 0); i++)
parsed_uuid_len = ble_advdata_search(adv_data.p_data, adv_data.data_len, &data_offset, ad_types[i]);
if (data_offset != 0)
uuid_type = ad_types[i];
if (data_offset == 0)
return false;
p_parsed_uuid = &adv_data.p_data[data_offset]; //The UUID we found
// if (parsed_uuid_len != 0)
// // Verify if any UUID matches the given UUID.
if (uuid_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE || uuid_type == BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE)
raw_uuid_len = UUID128_SIZE;
else if(uuid_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_COMPLETE || uuid_type == BLE_GAP_AD_TYPE_16BIT_SERVICE_UUID_MORE_AVAILABLE)
raw_uuid_len = UUID16_SIZE;
// for (uint16_t list_offset = 0; list_offset < parsed_uuid_len; lisraw_uuid_lent_offset += raw_uuid_len)
if (raw_uuid_len == UUID128_SIZE)
for (uint8_t ele = 0; ele < sizeof(m_uuid128); ele++)
if ( memcmp(p_parsed_uuid, &m_uuid128->uuid128[ele], raw_uuid_len) == 0)
NRF_LOG_INFO("matched uuid128 %x\r\n", m_uuid128->uuid128[ele]);
for (uint8_t ele = 0; ele < sizeof(m_uuid16); ele++)
// for (uint8_t id = 0; id <parsed_uuid_len; id =+ raw_uuid_len)
// NRF_LOG_INFO("uuid addr %x\r\n", &p_parsed_uuid[ele]);
if ( memcmp(&p_parsed_uuid[id], &m_uuid16[ele], raw_uuid_len) == 0)
NRF_LOG_INFO("matched uuid16 %x\r\n", m_uuid16[ele].uuid);
m_device[idx].is_not_empty = true; //Validating the list record
//Copy the UUID to our list of devices
memset(m_device[idx].uuid_buffer_1,0,UUID128_SIZE);
memcpy(m_device[idx].uuid_buffer_1, p_parsed_uuid, parsed_uuid_len);
// NRF_LOG_INFO("uuid - %x uuid_buff = %x \n", p_parsed_uuid[0], m_device[idx].uuid_buffer_1[0]);
memcpy(&m_device[idx].uuid_len, &parsed_uuid_len, sizeof(parsed_uuid_len));
memcpy(&m_device[idx].uuid_type, &uuid_type, sizeof(uuid_type));
memcpy(m_device[idx].addr,
sizeof(p_adv_report->peer_addr.addr));
// Search for advertising names.
field_len = ble_advdata_search(adv_data.p_data,
adv_data.data_len,
&dev_name_offset,
BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME);
if (field_len == 0)
adv_data.data_len,
&dev_name_offset,
BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME);
// If name is not found, then return.
if (field_len == 0)
return true;
memcpy(m_device[idx].dev_name, &adv_data.p_data[dev_name_offset], field_len);
m_device[idx].dev_name[field_len] = 0;
return true;
return true;
/**@brief Function for searching for a device name and adding it to a dynamic command.
* @details Use this function to parse the received advertising data and to find a given
* name in them either as 'complete_local_name' or as 'short_local_name'.
* @param[in] p_adv_report Advertising data to parse.
uint8_t idx = 0;
uint16_t field_len;
data_t adv_data;
// If address is duplicated, then return.
m_device[idx].addr,
/* update rssi value */
return;
// Add device data if an empty record is found.
if (!m_device[idx].is_not_empty)
if (peripheral_rssi > RSSI_THRESHOLD)
/* store peer address */
//connect to target
// if (p_adv_report->type.connectable && p_adv_report->peer_addr.addr[0] == 0xAB )
if (p_adv_report->type.connectable && connect == false )
connect_to_target(p_adv_report);
// /* store peer address */
/* Copy MAC ID and RSSI to known device list */
memcpy(temp_device.addr,
memcpy(&temp_device.RSSI_value_RK,
adv_data.data_len,
&dev_name_offset,
if (field_len == 0)
adv_data.data_len,
&dev_name_offset,
if (field_len == 0)
return;
return;
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
ret_code_t ret;
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
//init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
/** @brief Function for initializing BLE components.
void ble_init(void)
ble_stack_init();
gap_params_init();
gatt_init();
db_discovery_init();
services_init();
advertising_init();
peer_manager_init();
#ifdef RK_CLI
scan_init();
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, 0);
#ifdef RK_CLI
ret_code_t ret;
m_scanning = true;
void scan_stop(void)
ret_code_t ret;
m_scanning = false;
ASSERT(p_result);
ASSERT(p_addr);
if (result_len > BLE_GAP_ADDR_LEN)
return;
// char buffer[BLE_GAP_ADDR_LEN] = {0};
char tempbuffer = '\0';
memset(p_result, 0, result_len);
for (uint8_t i = 0; i < result_len; ++i)
sprintf(&tempbuffer, "%.2X", p_addr[result_len - (i+1)]);
strcat(p_result, &tempbuffer);
if (i < (result_len - 1))
strcat(p_result, ":");
ASSERT(p_result);
ASSERT(p_uuid);
if (result_len > 100)
return;
//Printing UUID in "8-4-4-4-12" format
char buffer[100] = {0};
memset(buffer, 0, 100);
for (uint8_t j = size; j >= 1; --j)
sprintf(buffer, "%.2X", p_uuid[j-1]);
strcat(p_result, buffer);
if ( size < UUID128_SIZE && (j == 3 || j == 5 || j == 7))
strcat(p_result, ",");
if (j ==13 || j ==11 || j==9 || j==7)
strcat(p_result, "-");
/* Below funciton displays the scanned device list */
void device_list(nrf_cli_t const *p_cli, scanned_device_t * p_device )
for (uint8_t i = 0; i < DEVICE_TO_FIND_MAX; i++)
if (p_device[i].is_not_empty)
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Device ");
char buffer[ADDR_STRING_LEN];
int_addr_to_hex_str(buffer, BLE_GAP_ADDR_LEN, p_device[i].addr);
char ubuffer[100]={0};
print_uuid(ubuffer, 100, p_device[i].uuid_buffer_1, p_device[i].uuid_len);
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s %s %ddB\r\n", buffer, p_device[i].dev_name, p_device[i].RSSI_value_RK);
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Known Device List:\n\r");
//print known device list
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "K Device ");
int_addr_to_hex_str(buffer, BLE_GAP_ADDR_LEN, (uint8_t *)k_device[i].addr);
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "%s %ddB uuid = %x\r\n", buffer, k_device[i].RSSI_value_RK, k_device[i].uuid);
static void scan_on_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
scan_start();
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scanning...\r\n");
static void scan_off_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
scan_stop();
nrf_cli_fprintf(p_cli, NRF_CLI_NORMAL, "Scan stopped.\r\n");
static void display_device_list_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
if (argc >= 2)
if (nrf_cli_help_requested(p_cli))
nrf_cli_help_print(p_cli, NULL, 0);
return;
NRF_CLI_ERROR,
"%s:%s%s\r\n",
argv[0],
" bad parameter ",
argv[1]);
return;
/* Print connectable devices from scan data.*/
scanned_device_t * p_device_list = scan_device_info_get();
device_list(p_cli, p_device_list);
static void default_cmd(nrf_cli_t const *p_cli, size_t argc, char **argv)
if (argc >= 2)
return;
NRF_CLI_ERROR,
"%s:%s%s\r\n",
argv[0],
" bad parameter ",
argv[1]);
return;
// Register "mpu" command and it's subcommands in CLI.
NRF_CLI_CREATE_STATIC_SUBCMD_SET(scan_commands)
NRF_CLI_CMD(on, NULL, "Scan on.", scan_on_cmd),
NRF_CLI_CMD(off, NULL, "Scan off.", scan_off_cmd),
NRF_CLI_SUBCMD_SET_END
NRF_CLI_CMD_REGISTER(scan, &scan_commands, "Commands for scan control", default_cmd);
NRF_CLI_CMD_REGISTER(devices, NULL, "print device list", display_device_list_cmd);
void idle_task(void * p_context)
bool erase_bonds = (bool)p_context;
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
nrf_pwr_mgmt_run();
task_yield();
static void core_init(void)
APP_ERROR_CHECK(NRF_LOG_INIT(app_timer_cnt_get));
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
uart_config.pseltxd = TX_PIN_NUMBER;
uart_config.pselrxd = RX_PIN_NUMBER;
uart_config.hwfc = NRF_UART_HWFC_DISABLED;
APP_ERROR_CHECK(nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO));
//APP_ERROR_CHECK(nrf_cli_start(&m_cli_uart));
APP_ERROR_CHECK(nrf_drv_clock_init());
APP_ERROR_CHECK(app_timer_init());
// Timer for refreshing scanned devices data.
APP_TIMER_DEF(adv_list_timer);
APP_ERROR_CHECK(app_timer_create(&adv_list_timer, APP_TIMER_MODE_REPEATED, adv_list_timer_handle));
APP_ERROR_CHECK(app_timer_start(adv_list_timer, FOUND_DEVICE_REFRESH_TIME, NULL));
APP_ERROR_CHECK(nrf_pwr_mgmt_init());
APP_ERROR_CHECK(nrf_cli_task_create(&m_cli_uart));
ret_code_t fds_test_init (void)
ret_code_t ret = fds_register(my_fds_evt_handler);
if (ret != FDS_SUCCESS)
return ret;
ret = fds_init();
return ret;
return NRF_SUCCESS;
/**@brief Function for application main entry.
bool erase_bonds;
core_init();
ble_init();
conn_params_init();
fds_test_init();
APP_ERROR_CHECK(nrf_cli_ble_uart_service_init());
NRF_LOG_RAW_INFO("BLE Nordic Uart Service started\r\n");
NRF_LOG_RAW_INFO("Press Tab to view all available commands.\r\n");
task_manager_start(idle_task, (void *)erase_bonds);
while (true)
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
nrf_cli_process(&m_cli_uart);
Hi
Am trying to establish nrf52 DK as peripheral with nRF connect application as central but am unable to establish connection between both.
Please debug the following code and help me out as am new to this device.
