Cut power to nRF52 to switch off system.
I would like to know the best place to cut the power in switch off sequence.
We have a IO to totally cut power to the IC (own board), I added PIN control to switch off the board inside (SDK 15.3 with SD):
static void shutdown_process(void){}
just before:
ret_code_t ret_code = sd_power_system_off();
I red that sd_power_system_off  does off (NRF_POWER->SYSTEMOFF) and other critical issues to switch off softdevice.
My question is it is safe to cut IC power at this place or it should be done on some other safest way.
The issue is I cannot put switch off pin control after call to sd_power_system_off() because (obviously) the system does not return from this call but cutting power before I am not sure if SD is notified properly that we are going to cut power.
Thks.
C
