Sending data to iOS crashes midway
Using NRF51822 + SoftDevice 130, version 2.0.0, I have written a program which reads data from on-chip flash memory and transfers it to smartphone once connection is established. In order to determine if connection is established I wait for event "BLE_GAP_EVT_CONNECTED" in "on_ble_evt" handler. After that data is transferred using "ble_nus_string_send".
When I connect to the device using NRF Toolbox app (in UART mode) on Android - All data is transferred correctly and can be seen in the application's Log.
When I connect to the device using the same app but this time on iOS - Data strarts to transfer correctly but hangs before all data is received by iPhone.
    Any particular reason for why you use such an old SDK? I suggest, if you are not far in your development to move to SDK12.3.0, which is the latest SDK for nRF51 - S130.
    What do you mean by "hangs before all data is received by iPhone"?
    I suspect that you are caught in an APP_ERROR_CHECK(). Probably in the part:
    err_code = ble_nus_string_send(...)
    Maybe you get err_code == NRF_ERROR_RESOURCES (= 19 or 0x13)?
    This means that the softdevice queue is full, and you need to wait for a BLE_EVT_TX_COMPLETE event before you can send more data. The reason this happens on the iPhone and not the Android may be because they are giving you different connection parameters, and that the connection parameters on the Android is allowing a higher throughput.
    You can add the BLE_EVT_TX_COMPLETE event in the on_ble_evt() function in main.c, and use this event to set a flag indicating that you can send more data when this event occurs.
    Edvin
  • I've actually already implemented waiting for BLE_EVT_TX_COMPLETE event to be generated every 1 word (4 bytes I send). As for the connections parameters, aren't they the same for both Android and iOS as my device is acting as Central and the phone is Peripheral.
     Are you sure? It may be right, but the typical use case is that the phone is acting as a central and the nRF is the peripheral. You also mention that you use ble_nus_string_send(), which is a peripheral API, while ble_nus_c_string_send() is the central equivalent function.
    I suspect that your phone is the central. And if your phone is the central it will decide the connection parameters, since it is always the phone that decides the connection parameters.
    However, did you check the return value of ble_nus(_c)_string_send()? Does it ever return != NRF_SUCCESS?
    Are there possibly any other function calls that returns != NRF_SUCCESS that is passed into an APP_ERROR_CHECK(err_code);?
    Try to define DEBUG in your preprocessor defines, turn off optimization, and set a breakpoint in app_error.c on line 54. Does it ever stop there?
    Edvin
  • Okay, indeed I am using ble_nus_string_send() NOT ble_nus_c_string_send(). So my device is peripheral after all and phone (Android/iOS) is central. The parameters I am setting on device's side are:
    /* Definitions */
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                           		/**< Include the service_changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define CENTRAL_LINK_COUNT              0                                           		/**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           1                                          			/**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define DEVICE_NAME                     "Nordic_TEST"                               		/**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  		/**< UUID type for the Nordic UART Service (vendor specific). */
    // Read this: https://www.argenox.com/library/bluetooth-low-energy/ble-advertising-primer/
    #define APP_ADV_INTERVAL                64// 560                                  			/**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      120                                         		/**< The advertising timeout (in units of seconds). */
    #define APP_TIMER_PRESCALER             0                                           		/**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           		/**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             		/**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(40, UNIT_1_25_MS)              		/**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           		/**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(6000, UNIT_10_MS)             		/**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  		/**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER) 		/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           		/**< Number of attempts before giving up the connection parameter negotiation. */
    The normal operation cycle of firmware is as follows:
    1. Gather data from sensors for X time and store in FLASH.
    2. At some point start advertising and wait for connection from smartphone.
    3. Upon connection established event, dump all the data to the smartphone.
    3. Disconnect from smartphone and stop advertising.
    4. Resume cycle with point 1.
    Meanwhile, the default behavior of APP_ERROR_CHECK(err_code); is to call NVIC_SystemReset(); when err_code != NRF_SUCCESS. Because of that I have placed breakpoint in the beginning of my main() in case the controller is reset. After flashing firmware and initial passing over that said breakpoint the program never again reaches it, which means the controller is never reset, which means it passes APP_ERROR_CHECKs successfully.
    Moreover, when my device finishes dumping the data it just continues its operational cycle as if nothing happened. I've ran a test without point 3. where I disconnect and stop advertising. The connection just stays open and device continues with gathering data. So now it seems like smartphone app just doesn't display all the data in the Log...I'm really confused by now.
  • Ok. So we agree that some time between you gathering the data, and the data being displayed on the phone, some records are lost.
    Can you please show me the function/place that you use ble_nus_string_send() ?
    Are you sure that you store the data in flash? If so, do you use the FDS module, or just fstorage? Or do you actually just store it in ram, in an array in your application?
    If you are using flash, maybe you fail to load all the flash records fast enough to keep up with the BLE communication?
    So:
    1: Show me how/where you use ble_nus_string_send();
    2: How do you store your data, and how do you fetch it before sending it with ble_nus_string_send() ?
    Edvin
