Enabling eDRX on mqtt_simple on nRF9160
I want to activate eDRX on mqtt_simple example and measure the current consumption. I guess based on the code, by enabling "CONFIG_LTE_EDRX_REQ" it will be activated. Is there anything else that I should do in order to reduce power consumption?
My other question is about measuring the current, I read in the current measurement instruction on this topic but I want to know if it is possible to use power profiler kit on nRF9160 to measure the power.
  • Update: Woops, forgot to answer your first question Slight smile Just add the following code to the mqtt simple example (after the modem_configure() function is a good place):
            err = lte_lc_edrx_req(true);
            if (err) {
                    printk("ERROR: set edrx %d\n", err);
                    return;
    This function should be defined in lte_lc.c. You can then easily check to see that edrx is set by using the following AT command in LTE Link Monitor:
    AT+CEDRXS?
    You can naturally also check to make sure that no error has been returned.
    No, you cannot use the power profiler kit to measure the nRF9160 DK current consumption. If you have the v0.8.5 nRF91 DK, just follow the User Guide found here. If you have an older version of the nRF91 DK (i.e. <v0.8.5), take a look at this devzone case.
  • Thanks. eDRX now is working. My development kit version is older than 0.8.5. Just one question. I am confused, should I cut the SB43 or SB44 for the current measurement?
  • Hi, Bjørn
    I want to set a keep alive value of MQTT while eDRX is enabled, but it doesn't work well. Could you give me any advice?
    Environment
    - hardware: nRF9160 DK 0.8.2
    - firmware: 0.7.0-29.alpha
    - nrf ver: 0.4.0
    - LTE-M
    - eDRX enable
    - mqtt_simple works fine with mosquitto MQTT broker
    - project based on mqtt_simple
    - antenna power is fine
    - eDRX service is available here
    AT+CEDRXS?
    OK
    AT+CEDRXS=1,4,"1000"
    I added MQTT_KEEPALIVE param to Kconfig and CONF_MQTT_KEEPALIVE param to pro.conf
    I've tested several conditions
    [condition]
    - CONFIG_LTE_EDRX_REQ_VALUE="0110" in prj.conf // 327.68 sec interval
    - CONF_MQTT_KEEPALIVE=300 in prj.conf
    [result]
    - eDRX doesn't work properly. When I send a message to a MQTT broker, the DK receives it right after that. There should be a delay due to the eDRX.
    [condition]
    [result]
    - The DK does not receive any message after 360sec followed by disconnection.
    This is the whole project.
    <Kconfig>
    menu "MQTT simple sample"
    config MQTT_PUB_TOPIC
    	string "MQTT publish topic"
    	default "my/publish/topic"
    config MQTT_SUB_TOPIC
    	string "MQTT subscribe topic"
    	default "my/subscribe/topic"
    config MQTT_CLIENT_ID
    	string "MQTT Client ID"
    	default "my-client-id"
    config MQTT_BROKER_HOSTNAME
    	string "MQTT broker hostname"
    	default "iot.eclipse.org"
    config MQTT_BROKER_PORT
    	int "MQTT broker port"
    	default 1883
    config MQTT_MESSAGE_BUFFER_SIZE
    	int ""
    	default 128
    config MQTT_PAYLOAD_BUFFER_SIZE
    	int ""
    	default 128
    config MQTT_KEEPALIVE
    	int ""
    	default 60
    endmenu
    menu "Zephyr Kernel"
    source "$ZEPHYR_BASE/Kconfig.zephyr"
    endmenu
    <prj.conf>
    # General config
    CONFIG_TEST_RANDOM_GENERATOR=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # CONFIG_LTE_EDRX_REQ_ACTT_TYPE="4"
    CONFIG_LTE_EDRX_REQ=y
    # 0100 81.92sec
    # 0101 163.84sec
    # 0110 327.68sec
    # 0111 655.36sec
    # LTE link control
    # BSD library
    CONFIG_BSD_LIBRARY=y
    # AT Host
    CONFIG_AT_HOST_LIBRARY=y
    # MQTT
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LIB_TLS=n
    # Appliaction
    CONFIG_MQTT_PUB_TOPIC="myPubTopic"
    CONFIG_MQTT_SUB_TOPIC="mySubTopic"
    CONFIG_MQTT_CLIENT_ID="myClientID"
    CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxx.com"
    CONFIG_MQTT_BROKER_PORT=1883
    CONFIG_MQTT_KEEPALIVE=300 # ADD here
    # Main thread
    CONFIG_MAIN_THREAD_PRIORITY=7
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    <main.c>
    #include <zephyr.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    #include <net/mqtt.h>
    #include <net/socket.h>
    #include <lte_lc.h>
    #define MQTT_USERNAME "username"
    #define MQTT_PASSWORD "password"
    /**@brief Initialize the MQTT client structure
    static void client_init(struct mqtt_client *client)
    	mqtt_client_init(client);
    	broker_init();
        /* Add from here */
        static struct mqtt_utf8 password;
    	static struct mqtt_utf8 user_name;
    	password.utf8 = (u8_t *)MQTT_PASSWORD;
    	password.size = strlen(MQTT_PASSWORD);
    	user_name.utf8 = (u8_t *)MQTT_USERNAME;
    	user_name.size = strlen(MQTT_USERNAME);
        /* to here */
    	/* MQTT client configuration */
    	client->broker = &broker;
    	client->evt_cb = mqtt_evt_handler;
    	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
    	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
    	client->password = &password; // Add here
    	client->user_name = &user_name; // Add here
    	client->protocol_version = MQTT_VERSION_3_1_0; // originally MQTT_VERSION_3_1_1
    	/* MQTT buffers configuration */
    	client->rx_buf = rx_buffer;
    	client->rx_buf_size = sizeof(rx_buffer);
    	client->tx_buf = tx_buffer;
    	client->tx_buf_size = sizeof(tx_buffer);
    	/* MQTT transport configuration */
    	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
    void main(void)
    	int err;
    	printk("The MQTT simple sample started\n");
    	modem_configure();
        /* ADD here */
        if (err) {
            return;
        /* ADD here */
    	client_init(&client);
    	err = mqtt_connect(&client);
    	if (err != 0) {
    		printk("ERROR: mqtt_connect %d\n", err);
    		return;
    	err = fds_init(&client);
    	if (err != 0) {
    		printk("ERROR: fds_init %d\n", err);
    		return;
    	while (1) {
    		err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
    		if (err < 0) {
    			printk("ERROR: poll %d\n", errno);
            err = mqtt_live(&client);
    		if (err != 0) {
    			printk("ERROR: mqtt_live %d\n", err);
    		if ((fds.revents & POLLIN) == POLLIN) {
    			err = mqtt_input(&client); // if a publish event comes, mqtt_evt_handler is called here
    			if (err != 0) {
    				printk("ERROR: mqtt_input %d\n", err);
    		if ((fds.revents & POLLERR) == POLLERR) {
    			printk("POLLERR\n");
    		if ((fds.revents & POLLNVAL) == POLLNVAL) {
    			printk("POLLNVAL\n");
    This is a test condition.
    Ideally, I want to set a longer keepalive value, like 1200(sec) to decrease power consumption.
    - keep alive of MQTT: 1200 sec
    - eDRX interval value: 655 sec
    I have been struggling with this issue more than two weeks, but I don't really get the eDRX behavior. Any advice?
  • Could you please open a new DevZone case? Thanks!
