I want to store a few parameters in flash. I don't want to use an external EEPROM because it takes an additional space on a board.
Does anyone know how to do it or a sample code?
Thank you in advance.
Hi
Zephyr contains a couple of different libraries for writing data into internal flash.
I would suggest you take a look at the NVS library, which is a good place to start. The documentation describes how to use the library, and points to an example also.
Best regards
Torbjørn
Flash Data Storage - FDS: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_fds.html
Flash Storage: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_fstorage.html
Examples for both are in the SDK.
Thank you for your reply!
I found the sample code related to nvs: ../nRF9160/ncs/zephyr/samples/subsys/nvs
This zephyr firmware version was tags/v1.13.99-ncs2, which seems not to support nRF9160 flash writing and reading functions. I had some errors when I copied the main.c and prj.conf, and used it. Then I updated zephyr, mcuboot, nerf, and nrfxlib folders.
zephyr: tags/v1.14.99-ncs1-rc2
mcuboot: tags/v1.3.99-ncs1-rc2
nerf: tags/v0.4.0-rc2
nrfxlib: tags/v0.4.0-rc2
The previous errors disappeared, but other errors ware caused.
Can you give me any advice?
I copy and use this code: https://github.com/NordicPlayground/fw-nrfconnect-zephyr/tree/master/samples/subsys/nvs
Building ‘zephyr/zephyr_prebuilt.elf’ from solution ‘build’ in configuration ‘Common’ 1> Linking ‘zephyr_prebuilt.elf’ 1> Memory region Used Size Region Size %age Used 1> FLASH: 27796 B 192 KB 14.14% 1> SRAM: 6216 B 64 KB 9.48% 1> IDT_LIST: 592 B 2 KB 28.91% 1> /usr/local/opt/gnuarmemb/gcc-arm-none-eabi-7-2018-q2-update/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/bin/ld: warning: orphan section `.gnu.linkonce.sw_isr_table' from `zephyr/libzephyr.a(isr_tables.c.obj)' being placed in section `.gnu.linkonce.sw_isr_table'. 1> zephyr/libzephyr.a(nrf5_power_clock.c.obj): In function `_clock_control_init': 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/drivers/clock_control/nrf5_power_clock.c:447: undefined reference to `_irq_priority_set' 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/drivers/clock_control/nrf5_power_clock.c:451: undefined reference to `_arch_irq_enable' 1> zephyr/libzephyr.a(nrf5_power_clock.c.obj): In function `_m16src_start': 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/drivers/clock_control/nrf5_power_clock.c:67: undefined reference to `_arch_irq_disable' 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/drivers/clock_control/nrf5_power_clock.c:90: undefined reference to `_arch_irq_enable' 1> zephyr/arch/arm/core/cortex_m/mpu/libarch__arm__core__cortex_m__mpu.a(arm_core_mpu.c.obj): In function `z_arch_configure_static_mpu_regions': 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/arch/arm/core/cortex_m/mpu/arm_core_mpu.c:130: undefined reference to `_ramfunc_ram_start' 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/arch/arm/core/cortex_m/mpu/arm_core_mpu.c:130: undefined reference to `_ramfunc_ram_size' 1> zephyr/kernel/libkernel.a(init.c.obj): In function `z_data_copy': 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/kernel/init.c:182: undefined reference to `_ramfunc_ram_size' 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/kernel/init.c:182: undefined reference to `_ramfunc_rom_start' 1> /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/kernel/init.c:182: undefined reference to `_ramfunc_ram_start' 1> collect2: error: ld returned 1 exit status Build failed
Hi
I have no problem building the example for either the nrf9160_pca10090 or the nrf52_pca10040 boards.
Can you delete the build folder and try opening the example again?
Could you take a screenshot of the parameters in the SES project importer?
Have you tried to open any of the 9160 examples in the nrf/samples/nrf9160 folder to see if they work?
Best regards
Torbjørn
OK. It works.I'm using v0.4.0 of nrf repository, the latest one.
I followed this instruction.
