I want to send data from nrf51822 through UART TX to esp8266.
I am trying to send data from nrf51822 through UART TX to esp8266. I've gone through the app_uart examples and I can recieve data through RX but having difficulty sending data through TX.
    Do you measure any signal on the TX pin?
    best regards
    Jared
  • having difficulty sending data through TX
    What "difficulty", exactly?
    What hardware are you using?
    Can you successfully communicate (Tx & Rx) with a PC terminal? You should get this working before adding complications like an  esp8266!
    On debugging serial comms in general: www.avrfreaks.net/.../2336161
  • This is my code so far.
    I changed the TX pin from 9 to 26. Since not working on 9, but still not receiving any values on esp8266 arduino serial port
    // NRF_LOG_BACKEND_SERIAL_UART_TX_PIN 26
    // NRF_LOG_BACKEND_SERIAL_UART_RX_PIN 11
    // Sending data through TX
    static void uart_loopback_test()
    uint32_t err_code;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < length; i++)
    			 while (app_uart_put(data[i]) != NRF_SUCCESS);
    		 nrf_delay_ms(10);
        return;
    // UART init
    static void uart_init(void)
        const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_ENABLED,
            false,
            UART_BAUDRATE_BAUDRATE_Baud9600
        APP_UART_FIFO_INIT( &comm_params,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                         //  APP_IRQ_PRIORITY_LOWEST,
    						APP_IRQ_PRIORITY_HIGHEST,
                           err_code);
  • Thanks for your reply. I've tried with a pc terminal.
    I've even tested the sending data to the esp8266 from a different device and it works. But when i try with the nrf51822, I do not receive any data at all.
    Please see my code above
  • I managed to get it working by changing APP_UART_FLOW_CONTROL_ENABLE to
    APP_UART_FLOW_CONTROL_DISABLED
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            APP_UART_FLOW_CONTROL_DISABLED,
            false,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
