How to transfer code to external board by using uVision5
I am currently utilizing the Keil uVision5 for debugging, but have confronted a problem which I cannot solve.
I managed to succeed in programming a soft device through the Keil uVision5, and was able to confirm that the code works in the nrf52832 bluetooth module in the development kit.
I also have a completed PCBt by reference from the circuit provided by Nordic.
My goal is to debug the code to an external board, but I am having trouble at this stage.
Is it possible to transfer the code into a soft device to an external board which I made by using the Keil uvision5 tool?
I am aware that we should connect the VDD, GND, SWDIO, SWCLK pin with the pin 20 in the development kit.
I have already read the documentations and instructions on your homepage online about the nRF52832, but I would like a more detailed instruction on how to perform this step.
Thank you for your help in advance.
External board which I made
(This is the external board which I made by using reference circuit.)
  • JaeJin said:
    When I tried to give voltage, I gave it through USB cable which is connected to computer.
    I'm not sure whether it is near 3.0V.
    Is it right? Or do I have to do another thing for giving voltage source?
    VDD on the DK is 3 V and is routed to the pin headers, see silkscreen.
    JaeJin said:
    what's the name of the Bluetooth module which is detected on my mobile phone ??
    The device name is set by the application code and is normally the same across boards.
