Examples for nRF52840 Dongle ADC Reading
I am using nRF52840 Dongle and I want to use AIN0 pin for reading a sensor data. I was using PIC for this kind of project(C Programming)  before nRF52840. Here my questions;
1) I am new at programming nRF52840 and i need some examples for Analog Digital Converter. So how can i make ADC configuration basically ? I tried to understand SAADC example but it uses timer interrup. I need to use it without any interrupt.
2) Which functions are using for getting value between 0-2048(for 11 bits res.) ?  In examples used 2 dimensions array for storage value of ADC results. I just want to store it an integer.
If we compare nRF52840  with PIC, nRF52840 is very complicate for me and it's libraries are not using basic C language. So i need some basic examples.
Thank you :)
  • I am new at programming nRF52840
    In that case, you should certainly be starting with the nRF52840-DK rather than the dongle.
    As the name suggests, the DK is specifically designed for Development use - not least because it comes with an on-board debugger.
    Nearly all of the SDK examples focus on the DKs.
    The dongle is great as a cheap platform once you have a working application - but the DK is the place to do learning & development.
    Which particular "PIC" are you talking about?
    The nRF52840 is a complete System on a Chip - "SoC" - with a high-performance, 32-bit, ARM Cortex-M4F CPU plus a complete radio susbsystem plus some pretty advanced peripherals.
    That is obviously going to be a lot more complicated that a simple little 8-bit microcontroller!
    But the basic principles remain the same.
    The libraries use standard 'C'.
  • Well, i tried to get DK but, because of customs duty it costs me about 250$-300$. Unfortunately, I must make do with dongle for a while. By the way i found some codes in Nordic Devzone. Is this work for Dongle? I think this is the basic one. Thanks for your reply.
    #include "nrf.h"
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "nrf_drv_adc.h"
    #include "nordic_common.h"
    #include "boards.h"
    #include "nrf_log.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    static nrf_adc_value_t       adc_value; /**< ADC buffer. */
    static nrf_drv_adc_channel_t m_channel_config = NRF_DRV_ADC_DEFAULT_CHANNEL(NRF_ADC_CONFIG_INPUT_2);
        UNUSED_RETURN_VALUE(NRF_LOG_INIT());
        NRF_LOG_PRINTF("ADC example\r\n");
        while (true)
            nrf_drv_adc_sample_convert(&m_channel_config,&adc_value);
            NRF_LOG_PRINTF("ADC buffer: %d\r\n",adc_value);
            nrf_delay_ms(100);
  • I must make do with dongle for a while.
    So do you have a J-Link?
    As noted, this is a complex part - trying to develop without a debugger is not advised!
    (other debuggers are available)
    See:
    https://devzone.nordicsemi.com/f/nordic-q-a/43760/adapting-the-blinky-example-from-the-nrf52840-dk-to-the-nrf52840-dongle/171340#171340
    So it's just the same as porting code for a PIC on one board to the same PIC on a different board - it's just the external hardware dependencies which need attention.
  • No, I have no J-Link  but i have embedded ST-Link on my STM32F429 Development Kit. I connected ST-Link's GND,VDD,SWDIO,SWDCLCK pins to nRF52840 dongle for programming it via uKeil. It didn't work. I didn't get any error when i was flashing blinky example but it didn't work Disappointed
