Hi all,
I creat a main task to process events, when the bluetooth connected, this main task can not work, and the bluetooth can still work.
I try to add the main task's priority, but it still unuseful.
below is my code:
the sdk is nRF5_SDK_15.0.0_a53641a,
work on SEGGER Embedded Studio for ARM 4.12,
//create main task in main()
UNUSED_VARIABLE(xTaskCreate(user_common_task, "COMMON_TASK", 256*3, NULL, 2, common_task_handle));
//the task function
static void user_common_task(void* arg)
common_irq_Semaphore = xSemaphoreCreateBinary();
for(;;)
if(xSemaphoreTake(common_irq_Semaphore, portMAX_DELAY ) != pdFALSE)
uint8_t ret = 0;
switch (key_evt)
case BSP_EVENT_KEY_0:
DspLog(0xDCCC, 1111);
case BSP_EVENT_KEY_0_LONG_PRESS:
DspLog(0xDeee, 2222);
if(ble_state == BLE_STATE_IDLE || ble_state == BLE_STATE_INIT)
hal_user_advertising_start(true);
//key event handler, send the semaphore to the main task to process the key event.
static void bsp_evt_handler(bsp_event_t evt)
key_evt = evt;
BaseType_t xHigherPriorityTaskWoken = pdFALSE;
xSemaphoreGiveFromISR(common_irq_Semaphore, &xHigherPriorityTaskWoken);
//ble init related called in main(),copy from the example(ble_app_hrs_freertos)
ble_state = BLE_STATE_INIT;
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
nrf_sdh_freertos_init(NULL, (void *)0);
void nrf_sdh_freertos_init(nrf_sdh_freertos_task_hook_t hook_fn, void * p_context)
NRF_LOG_DEBUG("Creating a SoftDevice task.");
m_task_hook = hook_fn;
BaseType_t xReturned = xTaskCreate(softdevice_task,
"BLE",
256*3,
(void *)0,
2,
&m_softdevice_task);
if (xReturned != pdPASS)
NRF_LOG_ERROR("SoftDevice task not created.");
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
/* This function gets events from the SoftDevice and processes them. */
static void softdevice_task(void * pvParameter)
NRF_LOG_DEBUG("Enter softdevice_task.");
if (m_task_hook != NULL)
m_task_hook(pvParameter);
while (true)
nrf_sdh_evts_poll(); // Let the handlers run first, in case the EVENT occured before creating this task.
vTaskSuspend(NULL);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
#if 1
ble_state = BLE_STATE_DISCON;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
ble_state = BLE_STATE_CON;
#if 1
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
Thanks.
