I have a couple of general questions regarding BLE packets, things that are not completely clear to me. I'm using SD S140 v6.1.0. I hope this doesn't end up in too many questions in one thread. For all the questions, assume a SoftDevice handling a single peripheral link.
First thing: I know that it is possible to send up to 6 notifications in a single connection interval. What if I increase the connection interval and the connection event length? Would it be possible to send more than 6? Or what is the purpose of increasing the connection event length?
I'm guessing it is also possible that the SD sometimes cannot send all 6 notifications in a single connection interval (assume that 6 notifications were already queued using sd_ble_gatts_hvx), depending on the connection parameters. Is this true (assuming a good quality link with no packet losses)? Or is it always possible to send 6? What if you set up something like connection interval of 7.5 ms, with maximum data length and ATT MTU? What if you set up the Coded PHY?
Assuming that the link quality is bad: If a notification can't be sent due to interference, will the SD try to send the same notification 6 times within the same connection interval?
Regarding the Coded PHY: I've read that when you use the Coded PHY, the maximum data length possible is 27 in order to avoid interference. However, it still looks like the nrf_ble_gatt module is accepting the max data length of 251 even when the Coded PHY has already been set up. Does the SoftDevice use a data length of 27 internally anyway?
I know that when the ATT MTU is larger than the supported data length, the data will be broken down in multiple packets. Does this still give better throughput or is it better to always keep the ATT MTU smaller than the data length? I'm not exactly sure whether having ATT MTU > DL introduces more overhead or not.
What happens if the connection event length is set up to be longer than the connection interval? I ask this because the event length must be set up during SD initialization and the connection interval is negotiable at runtime. It looks like the SoftDevice is smart enough to handle this but I just want to be sure and ask this.
I'm asking all these questions because I'm trying to get as much throughput as possible using the Coded PHY, but even following all the threads I could find on this I couldn't manage to achieve a high enough throughput. I need to get around 24 Kbps which is supposedly achievable, but I'm having trouble with that. Any input on that will also be deeply appreciated!
Thanks and sorry for all the questions at once!
