IAR ERROR [Li005]
I am trying to integrate some ble code into my project but it keeps giving me errors like:
Error[Li005]: no definition for "ble_advertising_on_sys_evt" [referenced from C:\Projects\advanced-shared-channel-reference-design\app\np_hub\iar\ReleaseBlaze\Obj\main.o]
while I have put ble_advertising.c into my project
I am very confused why that did not work
Can someone help me with that?
Thanks!
  • Not sure it will help but the usual issue is incorrect include paths. Project options C++ has something like this:
    $PROJ_DIR$\..\..\..\config
    $PROJ_DIR$\..\..\..\..\..\..\components
    $PROJ_DIR$\..\..\..\..\..\..\components\boards
    $PROJ_DIR$\..\..\..\..\..\..\components\drivers_nrf\nrf_soc_nosd
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\atomic
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\balloc
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\bsp
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\button
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\delay
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\experimental_section_vars
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\gfx
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\log
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\log\src
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\memobj
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\mutex
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\pwr_mgmt
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\queue
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\ringbuf
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\scheduler
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\spi_mngr
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\strerror
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\timer
    $PROJ_DIR$\..\..\..\..\..\..\components\libraries\util
    $PROJ_DIR$\..\..\..\..\..\..\components\toolchain\cmsis\include
    $PROJ_DIR$\..\..\..
    $PROJ_DIR$\..\..\..\..\..\..\external\fprintf
    $PROJ_DIR$\..\..\..\..\..\..\external\segger_rtt
    $PROJ_DIR$\..\..\..\..\..\..\external\thedotfactory_fonts
    $PROJ_DIR$\..\..\..\..\..\..\integration\nrfx
    $PROJ_DIR$\..\..\..\..\..\..\integration\nrfx\legacy
    $PROJ_DIR$\..\..\..\..\..\..\modules\nrfx
    $PROJ_DIR$\..\..\..\..\..\..\modules\nrfx\drivers\include
    $PROJ_DIR$\..\..\..\..\..\..\modules\nrfx\hal
    $PROJ_DIR$\..\..\..\..\..\..\modules\nrfx\mdk
    $PROJ_DIR$\..\config
    Often the include path for a specific file is simply missing, or if the project is in (or has been copied to) a different relative path the number of "..\" has to be adjusted for nearly every include. It's a pain, often easier by closing the project and manually editing the .ewp IAR project file
  • Hi, thanks for your reply, I have checked the paths and they seem correct
  • In 15.3.0 that function is depreciated ..
    void ble_advertising_on_sys_evt(uint32_t evt_id, void * p_context)
        // Changes to advertising and fds components have made this function obsolete.
        // This function will be removed in a future major release.
