issues with app timer module
      I am developing firmware for a custom NRF52840 based board. I am using softdevice 6.0.0 with SDK 15.0 and the SES environment.
I am trying to use three application timers:
1) driving the battery service to update a couple of characteristics every 30 seconds. This has been working fine since the very start of this project about 6 months ago
2) calling a handler that does sampling, filtering of data and writing a characteristic every 20ms. Time in this handler is in the order of 10-15 ms.
3) calling a handler that does 3 x i2c reads every 20ms however the same behaviour is seen with trigger rate of 10ms.
sdk_config is setup as follows.
// <e> APP_TIMER_ENABLED - app_timer - Application timer functionality
#ifndef APP_TIMER_ENABLED
#define APP_TIMER_ENABLED 1
// <o> APP_TIMER_CONFIG_RTC_FREQUENCY  - Configure RTC prescaler.
// <0=> 32768 Hz
// <1=> 16384 Hz
// <3=> 8192 Hz
// <7=> 4096 Hz
// <15=> 2048 Hz
// <31=> 1024 Hz
#ifndef APP_TIMER_CONFIG_RTC_FREQUENCY
#define APP_TIMER_CONFIG_RTC_FREQUENCY 0
// <o> APP_TIMER_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef APP_TIMER_CONFIG_IRQ_PRIORITY
#define APP_TIMER_CONFIG_IRQ_PRIORITY 6
// <o> APP_TIMER_CONFIG_OP_QUEUE_SIZE - Capacity of timer requests queue.
// <i> Size of the queue depends on how many timers are used
// <i> in the system, how often timers are started and overall
// <i> system latency. If queue size is too small app_timer calls
// <i> will fail.
#ifndef APP_TIMER_CONFIG_OP_QUEUE_SIZE
#define APP_TIMER_CONFIG_OP_QUEUE_SIZE 100
// <q> APP_TIMER_CONFIG_USE_SCHEDULER  - Enable scheduling app_timer events to app_scheduler
#ifndef APP_TIMER_CONFIG_USE_SCHEDULER
#define APP_TIMER_CONFIG_USE_SCHEDULER 1
// <q> APP_TIMER_KEEPS_RTC_ACTIVE  - Enable RTC always on
// <i> If option is enabled RTC is kept running even if there is no active timers.
// <i> This option can be used when app_timer is used for timestamping.
#ifndef APP_TIMER_KEEPS_RTC_ACTIVE
#define APP_TIMER_KEEPS_RTC_ACTIVE 0
// <h> App Timer Legacy configuration - Legacy configuration.
// <q> APP_TIMER_WITH_PROFILER  - Enable app_timer profiling
#ifndef APP_TIMER_WITH_PROFILER
#define APP_TIMER_WITH_PROFILER 0
// <q> APP_TIMER_CONFIG_SWI_NUMBER  - Configure SWI instance used.
#ifndef APP_TIMER_CONFIG_SWI_NUMBER
#define APP_TIMER_CONFIG_SWI_NUMBER 0
App timer for the battery service just works and has worked for months.
I then tried to add the timer for the sampling handler. The handler is called very slowly say once a second unless APP_TIMER_CONFIG_USE_SCHEDULER is set to 1. This is the only reason it is set in sdk_config. With APP_TIMER_CONFIG_USE_SCHEDULER set, the calls to the handler speed up and are probably running every 20ms but I haven't timed it yet.
Adding the third timer causes a hard NRF_ERROR_NOMEM on the call to  app_sched_event_put in app_timer.c. I have increased the queue up to 800 with no change in behaviour.
As far as I can see
  •  app_timer_init() is called from the main function on startup before any other calls to the module.
  • The sample timer is created from the main function at startup and started and stopped when the application needs to sample. Bluetooth is connected while sampling.
  • The battery timer gets created and started from the main function at startup.
  • The third timer is created and started on bluetooth connection. It is stopped when bluetooth disconnects.
This application is fairly large and complex. I am happy to provide code but need to narrow down what you want to see.
Many thanks in advance
Cheers Paul
    Just to make sure you are adjusting the correct queue size (not APP_TIMER_CONFIG_OP_QUEUE_SIZE).
    Have you tried upping the scheduler queue size? It's normally set in main:
    static void scheduler_init(void)
        APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    Håkon
  • Hi Hakon,
                     One of the issues I have is that I don't want to use the app scheduler for this.
    My real issue is that:
    1) I can only get the sample timer to run at ms rates if I use the app scheduler
    2) the third timer doesn't run at all.
    I think that this problem is related to the length of time in the sample handler - ~10-15ms. It is supposed to be called every 20ms and then the third timer every 10ms. The timing budget just doesn't work (15 + 10 > 20). Using the app scheduler just serialises the calls on a first come first served basis and moves the work out of interrupt time/context.
    In any case I dropped the use of the sample timer and am progressing.
    Cheers Paul
