I am trying out the udp_with_psm example from: https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/udp_with_psm as a first step in sending data via UDP/IP. I have edited the example by using an ntp host from Sweden and using errno to get plain text error. This is the code I am using:
/* * Copyright (c) 2018 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic */ #include <zephyr.h> #include <net/socket.h> #include <stdio.h> #include <uart.h> #include <string.h> #include <lte_lc.h> #include <errno.h> extern int errno; #define HOST "gbg1.ntp.se" #define PORT 123 #define RECV_BUF_SIZE 1024 #define SEND_BUF_SIZE 1024 u8_t recv_buf[RECV_BUF_SIZE]; /* As it is close to impossible to find * a proper UDP server, we just connect * to a ntp server and read the response */ struct ntp_format { u8_t flags; u8_t stratum; /* stratum */ u8_t poll; /* poll interval */ s8_t precision; /* precision */ u32_t rootdelay; /* root delay */ u32_t rootdisp; /* root dispersion */ u32_t refid; /* reference ID */ u32_t reftime_sec; /* reference time */ u32_t reftime_frac; /* reference time */ u32_t org_sec; /* origin timestamp */ u32_t org_frac; /* origin timestamp */ u32_t rec_sec; /* receive timestamp */ u32_t rec_frac; /* receive timestamp */ u32_t xmt_sec; /* transmit timestamp */ u32_t xmt_frac; /* transmit timestamp */ }; int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags) { int err; do { err = recv(fd, buf, size, flags); } while (err < 0 && errno == EAGAIN); return err; } int blocking_recvfrom(int fd, void *buf, u32_t size, u32_t flags, struct sockaddr *src_addr, socklen_t *addrlen) { int err; do { err = recvfrom(fd, buf, size, flags, src_addr, addrlen); } while (err < 0 && errno == EAGAIN); return err; } int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags) { int err; do { err = send(fd, buf, size, flags); } while (err < 0 && errno == EAGAIN); return err; } int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len) { int err; do { err = connect(fd, local_addr, len); } while (err < 0 && errno == EAGAIN); return err; } void setup_psm(void) { /* * GPRS Timer 3 value (octet 3) * * Bits 5 to 1 represent the binary coded timer value. * * Bits 6 to 8 defines the timer value unit for the GPRS timer as follows: * Bits * 8 7 6 * 0 0 0 value is incremented in multiples of 10 minutes * 0 0 1 value is incremented in multiples of 1 hour * 0 1 0 value is incremented in multiples of 10 hours * 0 1 1 value is incremented in multiples of 2 seconds * 1 0 0 value is incremented in multiples of 30 seconds * 1 0 1 value is incremented in multiples of 1 minute * 1 1 0 value is incremented in multiples of 320 hours (NOTE 1) * 1 1 1 value indicates that the timer is deactivated (NOTE 2). */ char psm_settings[] = CONFIG_LTE_PSM_REQ_RPTAU; printk("PSM bits: %c%c%c\n", psm_settings[0], psm_settings[1], psm_settings[2]); printk("PSM Interval: %c%c%c%c%c\n", psm_settings[3], psm_settings[4], psm_settings[5], psm_settings[6], psm_settings[7]); int err = lte_lc_psm_req(true); if (err < 0) { printk("Error setting PSM: %d Errno: %d\n", err, errno); } } void app_udp_start(void) { struct addrinfo *res; socklen_t addrlen = sizeof(struct sockaddr_storage); int err = getaddrinfo(HOST, NULL, NULL, &res); if (err < 0) { printf("getaddrinfo err: %s\n\r", strerror(errno)); return; } ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(PORT); struct sockaddr_in local_addr; local_addr.sin_family = AF_INET; local_addr.sin_port = htons(0); local_addr.sin_addr.s_addr = 0; int client_fd = socket(AF_INET, SOCK_DGRAM, 0); if (client_fd < 0) { printk("client_fd: %d\n\r", client_fd); goto error; } err = bind(client_fd, (struct sockaddr *)&local_addr, sizeof(local_addr)); if (err < 0) { printk("bind err: %d errno: %d\n\r", err, errno); goto error; } err = connect(client_fd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in)); if (err < 0) { printk("connect err: %d errno: %d\n\r", err, errno); goto error; } /* Just hard code the packet format */ u8_t send_buf[sizeof(struct ntp_format)] = { 0xe3 }; /*err = sendto(client_fd, send_buf, sizeof(send_buf), 0, (struct sockaddr *)res->ai_addr, addrlen);*/ err = send(client_fd, send_buf, sizeof(send_buf), 0); printk("sendto ret: %d\n\r", err); if (err < 0) { printk("sendto err: %d errno: %d\n\r", err, errno); goto error; } err = blocking_recvfrom(client_fd, recv_buf, sizeof(recv_buf), 0, (struct sockaddr *)res->ai_addr, &addrlen); if (err < 0) { printk("recvfrom err: %d errno: %d\n\r", err, errno); goto error; } else { printk("Got data back: "); for (int i = 0; i < err; i++) { printk("%x ", recv_buf[i]); } printk("\n"); } error: printk("Finished\n"); (void)close(client_fd); } static volatile bool run_udp; void app_timer_handler(struct k_timer *dummy) { static u32_t minutes; minutes++; /* This shall match the PSM interval */ if (minutes % 10 == 0) { run_udp = true; } printk("Elapsed time: %d\n", minutes); } K_TIMER_DEFINE(app_timer, app_timer_handler, NULL); void timer_init(void) { k_timer_start(&app_timer, K_MINUTES(1), K_MINUTES(1)); } /**@brief Configures modem to provide LTE link. Blocks until link is * successfully established. */ int main(void) { if (!IS_ENABLED(CONFIG_AT_HOST_LIBRARY)) { /* Stop the UART RX for power consumption reasons */ NRF_UARTE0_NS->TASKS_STOPRX = 1; } printk("UDP test with PSM\n"); app_udp_start(); setup_psm(); timer_init(); while (1) { k_sleep(500); if (run_udp == true) { printk("Run UDP\n"); run_udp = false; app_udp_start(); } } return 1; }
I get the following output on my serial port:
So I tried changing from hints.ai_family = AF_UNSPEC; to hints.ai_family = AF_INET; in net_sockets.h but it is still the same problem. I even tried AF_INET6 just to check all possibilities but this does not seem to make any difference.
Is there some other place this should be edited or have I misunderstood the problem?
Kind regards
Samuel
