% chances to detect advertising data by a central
Hello!
I currently have 2 nR52DK using SDK14 and SDK15:
1) Beacon based on the beacon example
2) Central based on app blinky central + multirole
Then, I modified the central to filter the advertisement from the beacon using our company ID, so it works pretty good when the advertising interval is below 100ms
testing settings:
-advertising interval 20ms for the beacon
 -Scanning interval 250ms and Scan Window 25ms Central
The Central receives advertising packets every 250ms
Desired settings:
-Advertising interval 10000ms for the beacon
-Scanning Interval 250ms and Scan window 25ms for the central
The central is not receiving any advertising packet for long runs, e.g 1-6hours
My question: Is there any equation to calculate the chances a central detects advertising packets depending on settings (advertising/scan interval)?
additional info:
For my application, I am using 10000ms adv interval to maximize the battery duration, and the 250ms for scanning interval it is because  we use the center as a multirole with concurrent connections, where if I reduce the scanning interval we could lose connections links
Regards
