Transfert the firmware update from the PC with the library pc-nrf-dfu-js.
Here is my setup, NRF52832 PCA10040 s132, sdk 13.0.0.
I work on Windows 10 with a server (The aim is to do it from a Raspberry later) which one is connected to my sensors with BLE.
I am trying to transfert the firmware update from the PC with the library pc-nrf-dfu-js. This library is announced like the following devices are supported:
  • USB SDFU:
    • PCA10056 nRF52840 Development Kit
    • PCA10059 nRF52840 Dongl
BUT this library contains the DfuTransportNoble class which allows the device firmware update with BLE.
I modified the library a bit (I put the PRN set to 0 and change the value of MTU from 23 to 20) in order to match with the sdk 13.0.0 DFU bootloader
My sensors work with buttonless DFU service.
My sensor is currently in bootloader mode and I can connect to it (DfuTarg) and start the updating. The library is able to send the init packet, the sensor validates it, then the library try to send the firmware packet but the transfert of data packet stop after some couple of 20 bytes packets... and seems to disconnect in these conditions :
I can see in the terminal of Visual Stutio Code of the compiled libraries nrf-dfu-cjs.js that the whole function process so it sent all the 4096 bytes of firmware packets and ask for checksum to sensor.
I can see on the terminal of J-link RTT viewer that the sensor after sending answer to CreatingObject, receives only a couple of 20bytes firmware packets and then nothing else, it stopped.
I got on the terminal VSC from the library side these errors :
2019-05-10T12:32:07.531Z [error] uncaughtException: LIBUSB_ERROR_IO
Error: LIBUSB_ERROR_IO
at startTransfer (E:\workspace\xxx\hub\xxx_hub\node_modules\usb\usb.js:352:6)
at Transfer.transferDone (E:\workspace\xxx\hub\xxx_hub\node_modules\usb\usb.js:340:4)
2019-05-10T12:32:07.534Z [error] uncaughtException: LIBUSB_TRANSFER_STALL
Error: LIBUSB_TRANSFER_STALL
2019-05-10T12:32:07.537Z [error] uncaughtException: LIBUSB_TRANSFER_ERROR
Error: LIBUSB_TRANSFER_ERROR
2019-05-10T12:32:07.540Z [error] uncaughtException: LIBUSB_TRANSFER_ERROR
2019-05-10T12:32:07.543Z [error] uncaughtException: LIBUSB_TRANSFER_ERROR
2019-05-10T12:32:07.545Z [error] uncaughtException: LIBUSB_TRANSFER_ERROR
I don't find the reason of these errors.
NB : I tried to do the update with debug mode with breakpoint placed when sending 20 bytes packets and the sensor can receive around 1200-1300 bytes then stop...
Do you have any idea of the cause of this problem ? I will post another comment with a new test right after.
Thank you in advance !!
Alan
