Hello. I have problem with GPS example for nrf9160
I have:
Dev Board: PCA100900 0.8.5 2019.7
Source code:
mcuboot: v1.3.99 aebd4b96d2abbeea5a3392c623369dd61ddf40cb
nrf: v0.4.0 f9251026121264abc980a6c1e7928a802e8ab6e6
nrfxlib: v0.4.0 09bdd47ce20fd0ef0721eeb7c2eed10b5a199e0d
zephyr: v1.13.99 6c9637972f54e39640420c1e6ae096ac214c587c
Embedded studio: 4.16
I'm use this firmware https://www.nordicsemi.com/Products/Low-power-cellular-IoT/nRF9160/Download#infotabs
Build process will be fine for GPS sample code. But after uploading the source code to the MCU, I have this output on the UART interface.
***** Booting Zephyr OS v1.13.99-ncs1-1823-g715d2df3dd ***** Secure Boot: configure flash Secure Boot: SPU: set region 0 as Secure Secure Boot: SPU: set region 1 as Secure Secure Boot: SPU: set region 2 as Secure Secure Boot: SPU: set region 3 as Secure Secure Boot: SPU: set region 4 as Secure Secure Boot: SPU: set region 5 as Secure Secure Boot: SPU: set region 6 as Secure Secure Boot: SPU: set region 7 as Secure Secure Boot: SPU: set Flash region 8 as Non-Secure Secure Boot: SPU: set Flash region 9 as Non-Secure Secure Boot: SPU: set Flash region 10 as Non-Secure Secure Boot: SPU: set Flash region 11 as Non-Secure Secure Boot: SPU: set Flash region 12 as Non-Secure Secure Boot: SPU: set Flash region 13 as Non-Secure Secure Boot: SPU: set Flash region 14 as Non-Secure Secure Boot: SPU: set Flash region 15 as Non-Secure Secure Boot: SPU: set Flash region 16 as Non-Secure Secure Boot: SPU: set Flash region 17 as Non-Secure Secure Boot: SPU: set Flash region 18 as Non-Secure Secure Boot: SPU: set Flash region 19 as Non-Secure Secure Boot: SPU: set Flash region 20 as Non-Secure Secure Boot: SPU: set Flash region 21 as Non-Secure Secure Boot: SPU: set Flash region 22 as Non-Secure Secure Boot: SPU: set Flash region 23 as Non-Secure Secure Boot: SPU: set Flash region 24 as Non-Secure Secure Boot: SPU: set Flash region 25 as Non-Secure Secure Boot: SPU: set Flash region 26 as Non-Secure Secure Boot: SPU: set Flash region 27 as Non-Secure Secure Boot: SPU: set Flash region 28 as Non-Secure Secure Boot: SPU: set Flash region 29 as Non-Secure Secure Boot: SPU: set Flash region 30 as Non-Secure Secure Boot: SPU: set Flash region 31 as Non-Secure Secure Boot: configure SRAM Secure Boot: SPU: set SRAM region 0 as Secure Secure Boot: SPU: set SRAM region 1 as Secure Secure Boot: SPU: set SRAM region 2 as Secure Secure Boot: SPU: set SRAM region 3 as Secure Secure Boot: SPU: set SRAM region 4 as Secure Secure Boot: SPU: set SRAM region 5 as Secure Secure Boot: SPU: set SRAM region 6 as Secure Secure Boot: SPU: set SRAM region 7 as Secure Secure Boot: SPU: set SRAM region 8 as Non-Secure Secure Boot: SPU: set SRAM region 9 as Non-Secure Secure Boot: SPU: set SRAM region 10 as Non-Secure Secure Boot: SPU: set SRAM region 11 as Non-Secure Secure Boot: SPU: set SRAM region 12 as Non-Secure Secure Boot: SPU: set SRAM region 13 as Non-Secure Secure Boot: SPU: set SRAM region 14 as Non-Secure Secure Boot: SPU: set SRAM region 15 as Non-Secure Secure Boot: SPU: set SRAM region 16 as Non-Secure Secure Boot: SPU: set SRAM region 17 as Non-Secure Secure Boot: SPU: set SRAM region 18 as Non-Secure Secure Boot: SPU: set SRAM region 19 as Non-Secure Secure Boot: SPU: set SRAM region 20 as Non-Secure Secure Boot: SPU: set SRAM region 21 as Non-Secure Secure Boot: SPU: set SRAM region 22 as Non-Secure Secure Boot: SPU: set SRAM region 23 as Non-Secure Secure Boot: SPU: set SRAM region 24 as Non-Secure Secure Boot: SPU: set SRAM region 25 as Non-Secure Secure Boot: SPU: set SRAM region 26 as Non-Secure Secure Boot: SPU: set SRAM region 27 as Non-Secure Secure Boot: SPU: set SRAM region 28 as Non-Secure Secure Boot: SPU: set SRAM region 29 as Non-Secure Secure Boot: SPU: set SRAM region 30 as Non-Secure Secure Boot: SPU: set SRAM region 31 as Non-Secure Secure Boot: configure peripherals Secure Boot: MSP_NS 2002c790 Secure Boot: prepare to jump to Non-Secure image ***** Booting Zephyr OS kitprod_w49 ***** Application started LTE LC config ... [00:00:00.929,809] [1;31m<err> net_if.net_if_init: There is no network interface to work with![0m
The MCU does not send any additional data. He should send the GPS position. SIM card is insert on the slot.
