Static Provisioner - ACCESS_STATUS_INSUFFICIENT_RESOURCES
I have a problem with the BLE mesh light example using the static provisioner. I have modified the example to have multiple Generic OnOff servers. Client and Servers are working using nRF mesh to provision and set up publish/subscribe.
I have modified the configuration steps in the provision code to be able to setup all generic OnOff as i wanted. It have been working to subscribe to the client but when i added a publish configuration step i get an error. I have tried to limit the steps and changed to only publishing from the servers to the client and that is also working.
I'm getting opcode error 5.
<t:    2212109>, node_setup.c,  289, opcode status field: 5
Which is
ACCESS_STATUS_INSUFFICIENT_RESOURCES             = 0x05, /**< The node cannot store provided information due to insufficient resources on node. */
I'm having a hard time to debug this i dont understand what the insufficient resources on the node actually means and how to fix it whether it is on the Provision device or Server node?
Michael
  • Hi Simon,
    Unfortunately it did not seem to work. I used the Serial provision and had enabled offloading on the provisioneer. Confirmed the offloading was enabled and working, output below.
    main.c,   77, ----- Bluetooth Mesh Serial Interface Application -----
    main.c,   63, Enabling ECDH offloading...
    main.c,   66, Initializing serial interface...
    serial_handler_prov.c,  267, Generating encryption keypair...
    main.c,   87, Initialization complete!
    mesh_app_utils.c,   65, Device UUID (raw): FAB30A2AA21D9B4F9851E2375CC43CC2
    mesh_app_utils.c,   70, Device UUID : 2A0AB3FA-1DA2-4F9B-9851-E2375CC43CC2
    main.c,   98, Bluetooth Mesh Serial Interface Application started!
    Provisioned and tried to configure the node the same as static provisioneer but i still got AccessStatus.INSUFFICIENT_RESOURCES when trying to add publication.
    pyACI:
    In [1]: db = MeshDB("database/example_database.json")
    In [2]: p = Provisioner(device,db)
    In [3]: 2019-05-17 10:55:57,692 - INFO - COM4: Success
    2019-05-17 10:55:57,696 - INFO - COM4: Success
    2019-05-17 10:55:57,702 - INFO - COM4: SubnetAdd: {'subnet_handle': 0}
    2019-05-17 10:55:57,707 - INFO - COM4: AppkeyAdd: {'appkey_handle': 0}
    2019-05-17 10:55:57,713 - INFO - COM4: AppkeyAdd: {'appkey_handle': 1}
    In [3]: p.scan_start()
    In [4]: 2019-05-17 10:56:00,373 - INFO - COM4: Success
    2019-05-17 10:56:01,113 - INFO - COM4: Received UUID 450cf845108b6c4480c73736a1cbc479 with RSSI: -18 dB
    In [4]: p.scan_stop()
    In [5]: 2019-05-17 10:56:03,929 - INFO - COM4: Success
    In [5]: p.provision(name="lightBulb1")
    In [6]: 2019-05-17 10:56:08,569 - INFO - COM4: Provision: {'context': 0}
    2019-05-17 10:56:08,582 - INFO - COM4: Link established
    2019-05-17 10:56:08,637 - INFO - COM4: Received capabilities
    2019-05-17 10:56:08,638 - INFO - COM4: Number of elements: 2
    2019-05-17 10:56:08,642 - INFO - COM4: OobUse: {'context': 0}
    2019-05-17 10:56:08,840 - INFO - COM4: ECDH request received
    2019-05-17 10:56:08,848 - INFO - COM4: EcdhSecret: {'context': 0}
    2019-05-17 10:56:09,168 - INFO - COM4: Provisioning complete
    2019-05-17 10:56:09,168 - INFO - COM4:  Address(es): 0x10-0x11
    2019-05-17 10:56:09,169 - INFO - COM4:  Device key: a5afe5f29aaa252b40c9c81c8273ef2e
    2019-05-17 10:56:09,171 - INFO - COM4:  Network key: 18eed9c2a56add85049ffc3c59ad0e12
    2019-05-17 10:56:09,172 - INFO - COM4: Adding device key to subnet 0
    2019-05-17 10:56:09,173 - INFO - COM4: Adding publication address of root element
    2019-05-17 10:56:09,178 - INFO - COM4: DevkeyAdd: {'devkey_handle': 8}
    2019-05-17 10:56:09,179 - INFO - COM4: AddrPublicationAdd: {'address_handle': 0}
    2019-05-17 10:56:09,270 - INFO - COM4: Provisioning link closed
    In [6]: cc = ConfigurationClient(db)
    In [7]: device.model_add(cc)
    In [8]: cc.publish_set(8,0)
    In [9]: cc.composition_data_get()
    In [10]: 2019-05-17 10:56:42,685 - INFO - COM4: PacketSend: {'token': 1}
    2019-05-17 10:56:42,690 - INFO - COM4: {event: MeshTxComplete, data: {'token': 1}}
    2019-05-17 10:56:43,324 - INFO - COM4.ConfigurationClient: Received composition data (page 0x00): {
      "cid": "0059",
      "pid": "0000",
      "vid": "0000",
      "crpl": 40,
      "features": {
        "relay": 0,
        "proxy": 0,
        "friend": 2,
        "low_power": 2
      "elements": [
          "index": 0,
          "location": "0000",
          "models": [
              "modelId": "0000"
              "modelId": "0002"
              "modelId": "1000"
          "index": 1,
          "location": "0000",
          "models": [
              "modelId": "1000"
    In [10]: cc.appkey_add(0)
    In [11]: 2019-05-17 10:56:52,964 - INFO - COM4: PacketSend: {'token': 2}
    2019-05-17 10:56:53,005 - INFO - COM4: {event: MeshTxComplete, data: {'token': 2}}
    2019-05-17 10:56:53,029 - INFO - COM4.ConfigurationClient: Appkey status: AccessStatus.SUCCESS
    2019-05-17 10:56:53,032 - INFO - COM4.ConfigurationClient: Appkey add 0 succeded for subnet 0 at node 0010
    In [11]: cc.model_app_bind(db.nodes[0].unicast_address,0,mt.ModelId(0x1000))
    In [12]: 2019-05-17 10:57:00,256 - INFO - COM4: PacketSend: {'token': 3}
    2019-05-17 10:57:00,262 - INFO - COM4: {event: MeshTxComplete, data: {'token': 3}}
    2019-05-17 10:57:00,273 - INFO - COM4.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS
    2019-05-17 10:57:00,276 - INFO - COM4.ConfigurationClient: Appkey bind 0 to model 1000 at 0010
    In [12]:
        ...: cc.model_app_bind(db.nodes[0].unicast_address+1,0,mt.ModelId(0x1000))
    In [13]: 2019-05-17 10:57:07,825 - INFO - COM4: PacketSend: {'token': 4}
    2019-05-17 10:57:07,841 - INFO - COM4: {event: MeshTxComplete, data: {'token': 4}}
    2019-05-17 10:57:07,856 - INFO - COM4.ConfigurationClient: Model app bind status: AccessStatus.SUCCESS
    2019-05-17 10:57:07,859 - INFO - COM4.ConfigurationClient: Appkey bind 0 to model 1000 at 0011
    In [13]: d[0].send(cmd.AddrPublicationAdd(db.nodes[0].unicast_address+1))
    In [14]: 2019-05-17 10:57:14,741 - INFO - COM4: AddrPublicationAdd: {'address_handle': 1}
    In [14]: gc = GenericOnOffClient()
    In [15]: device.model_add(gc)
    In [16]: gc.publish_set(0,0)
    In [17]: gc.set(True)
    In [18]: 2019-05-17 10:57:39,369 - INFO - COM4: PacketSend: {'token': 5}
    2019-05-17 10:57:39,383 - INFO - COM4: {event: MeshTxComplete, data: {'token': 5}}
    2019-05-17 10:57:39,396 - INFO - COM4.GenericOnOffClient: Present OnOff: on
    In [18]: gc.set(False)
    In [19]: 2019-05-17 10:57:46,046 - INFO - COM4: PacketSend: {'token': 6}
    2019-05-17 10:57:46,060 - INFO - COM4: {event: MeshTxComplete, data: {'token': 6}}
    2019-05-17 10:57:46,078 - INFO - COM4.GenericOnOffClient: off
    In [19]: gc1 = GenericOnOffClient()
    In [21]: device.model_add(gc1)
    In [22]: gc1.publish_set(0,1)
    In [23]: gc1.set(True)
    In [24]: 2019-05-17 10:58:36,088 - INFO - COM4: PacketSend: {'token': 7}
    2019-05-17 10:58:36,097 - INFO - COM4: {event: MeshTxComplete, data: {'token': 7}}
    2019-05-17 10:58:36,122 - INFO - COM4.GenericOnOffClient: Present OnOff: on
    2019-05-17 10:58:36,124 - INFO - COM4.GenericOnOffClient: Present OnOff: on
    In [24]: gc1.set(False)
    In [25]: 2019-05-17 10:58:41,347 - INFO - COM4: PacketSend: {'token': 8}
    2019-05-17 10:58:41,354 - INFO - COM4: {event: MeshTxComplete, data: {'token': 8}}
    2019-05-17 10:58:41,375 - INFO - COM4.GenericOnOffClient: off
    2019-05-17 10:58:41,376 - INFO - COM4.GenericOnOffClient: off
    In [25]: cc.model_subscription_add(db.nodes[0].unicast_address,0xC001, mt.ModelId(0x1000))
    In [26]: 2019-05-17 10:58:58,920 - INFO - COM4: PacketSend: {'token': 9}
    2019-05-17 10:58:58,936 - INFO - COM4: {event: MeshTxComplete, data: {'token': 9}}
    2019-05-17 10:58:58,956 - INFO - COM4.ConfigurationClient: Model subscription status: AccessStatus.SUCCESS
    2019-05-17 10:58:58,959 - INFO - COM4.ConfigurationClient: Added subscription 'c001' to model 1000 at element 0010
    In [26]: cc.model_subscription_add(db.nodes[0].unicast_address,0xC000, mt.ModelId(0x1000))
    In [27]: 2019-05-17 10:59:06,737 - INFO - COM4: PacketSend: {'token': 10}
    2019-05-17 10:59:06,741 - INFO - COM4: {event: MeshTxComplete, data: {'token': 10}}
    2019-05-17 10:59:06,760 - INFO - COM4.ConfigurationClient: Model subscription status: AccessStatus.SUCCESS
    2019-05-17 10:59:06,764 - INFO - COM4.ConfigurationClient: Added subscription 'c000' to model 1000 at element 0010
    In [27]: cc.model_subscription_add(db.nodes[0].unicast_address+1,0xC000, mt.ModelId(0x1000))
    In [28]: 2019-05-17 10:59:13,337 - INFO - COM4: PacketSend: {'token': 11}
    2019-05-17 10:59:13,352 - INFO - COM4: {event: MeshTxComplete, data: {'token': 11}}
    2019-05-17 10:59:13,371 - INFO - COM4.ConfigurationClient: Model subscription status: AccessStatus.SUCCESS
    2019-05-17 10:59:13,374 - INFO - COM4.ConfigurationClient: Added subscription 'c000' to model 1000 at element 0011
    In [28]: cc.model_subscription_add(db.nodes[0].unicast_address+1,0xC002, mt.ModelId(0x1000))
    In [29]: 2019-05-17 10:59:19,969 - INFO - COM4: PacketSend: {'token': 12}
    2019-05-17 10:59:19,976 - INFO - COM4: {event: MeshTxComplete, data: {'token': 12}}
    2019-05-17 10:59:19,996 - INFO - COM4.ConfigurationClient: Model subscription status: AccessStatus.SUCCESS
    2019-05-17 10:59:19,999 - INFO - COM4.ConfigurationClient: Added subscription 'c002' to model 1000 at element 0011
    In [29]: cc.model_publication_set(db.nodes[0].unicast_address+1,mt.ModelId(0x1000), mt.Publish(0xCEEE, index=0,ttl=1))
    In [30]: 2019-05-17 10:59:57,101 - INFO - COM4: PacketSend: {'token': 13}
    2019-05-17 10:59:57,146 - INFO - COM4: {event: MeshTxComplete, data: {'token': 13}}
    2019-05-17 10:59:57,199 - INFO - COM4.ConfigurationClient: Model publication status: AccessStatus.INSUFFICIENT_RESOURCES
    Best Regards,
    Michael
    Where you able to fix this memory problem? I have the same problem with roughly the same setup.
    Mathias
