nRF52832 BT832XE randomly disconnects
So, after using my Devkit and everything working OK as far as I can tell, I decided to order up a bare BT832XE module and place it on my PCB.
Flashed it with the same firmware inside SEGGER using the Nordic PCA10040 devkit.
Seems to connect, everything works fine. for a little bit. Then I will get a random disconnect. It does not show up at all in the debug terminal. as far as it knows, it still thinks its connected.
When I hit pause, it stops at DEADBEEF. With no rhyme or reason as to why.
I tried recompiling as debug, and then tried again. Same thing. the disconnects are random. it can happen 30 seconds in, and it can happen as late as 4 to 8 minutes. But it ALWAYS happens.
I tried adjusting the Clock to 500 with its internal oscillator (not using a crystal externally). No difference. I even tried adding extra bypass capacitance near the module on my PCB, the voltage going in appears to be stable so thats not it.
Any thoughts?
Parents Reply
  • I assume the module manufacturer has a reference layout for their module and that you have followed that? You could also check against the reference layout in nRF52832 product specification against the module.
    But are you sure that you everything is soldered correctly and that you do not have additional pieces of wire/shorts or maybe poor soldering connections?
    Just so it is clear, this only happens on the custom board? Not the nordic DK?
