My application uses the nRF51822 with a GPIO configured as output and another GPIO is configured as input. Connected to the GPIO_OUT is a resistive load (Rload) which then connected to GPIO_IN. When GPIO_OUT drives a '1' and if the load has low resistance, we would expecte a '1' at GPIO_IN.
GPIO_OUT ------------------ Rload -----------------------GPIO_IN
Per spec, the VDD is 3.3V.
With GPIO_PIN_CNF_DRIVE is set to S0S1, the spec say this would drive 0.5mA. The max Rload measdured to be around 6K ohm.
When GPIO_PIN_CFG_DRIVE is set to H0H1, we get the same result.
I would expect the high-drive to allow for more resistance on the load.
Is this correct? Why would the S0S1 and H0H1 have the same result?
