Hi everyone,
I am facing the weirdest problem here.
I am working on a custom board using the NRF52832 which I was able to program without issues. I have been working with the NRF52 for a couple of here now, so I have a decent understanding of the whole environment. I use Segger Embedded Studio and occasionally nrfjprog command line.
The problem I have encountered is that I was modifying the current firmware we use on our board, and at a given point I was not able to communicate with the board anymore. On Segger Embedded Studio I got the error message "Failed to connect to target. No idcode detected" which is normally given when the board is not powered. Weird, but ok I though there was something wrong, so I moved to command line.
If I try to erase the whole chip with nrfjprog -e I got a "Segmentation fault. Core dumped" error. Same message if I try with a nrf52832 --recovery command.
The command line tools and segger embedded studio work fine with the development kits and with other custom boards (not of the same family of the broken one), so I thought there was something wrong with the board I am using, so i just took a second one. I programmed the firmware and I got the same problem.
Now, before I brick all our stock, is there any way I can recover the bricked boards?
Thanks for your help
