Problem with MQTT_Simple
I am having a problem running MQTT_Simple on my nRF9160 DK.
The COM Port shows the following:
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x4002a514
***** Hardware exception *****
Current thread ID = 0x20000324
Faulting instruction address = 0x6704
Fatal fault in essential thread! Spinning...
I have recently updated SES, but the code still produces the bus fault.
Case ID: 226428 seems to be similar, but the discussion involves several "experiments" only some of which were productive.
So, could someone explicitly lists the steps needed to get this example working.  I wish to use it as the basis for a new product that sends data to the cloud.
Thank you,
-Craig Goldman
  • The monitor is acting different this morning.
    Also, I'm not sure this is a good location for cellular connection.  I'll try everything again at a better location this weekend.
    Here is Monitor snap shot
  • More interesting (promising?) information regarding mqtt_simple.
    I decided to re-build and re-download mqtt_simple on the board in a very strong cellular area.
    I also decided to activate the LTE_Monitor instead of the terminal emulator.
    When I reset the board, I got the same boot-up and the same error messages....
    ***** Booting Zephyr OS v1.14.99-ncs1-587-g5c5ba77d0170 *****
    The MQTT simple sample started
    LTE Link Connecting ...
    LTE Link Connected!
    ERROR: getaddrinfo failed 22
    ERROR: mqtt_connect -47
    Per earlier instructions, I send the command AT+CFUN?.  On the third try, the board sprung to life - the modem activated and the terminal every 10 seconds or so would send "AT+CESQ" and the device would respond with +CESQ: 99,99,255,255,255,76
    Eventually the "LTE" indicated it was searching.  It did this for awhile until I sent another AT+CFUN? command (using the push button this time).
    Everything now seems to be connected.
    Here are a couple of screen shots.
    I'm not sure how to attach the log file, if you are interested.
    This looks very good to me.  (Please tell me if I am being overly optimistic.)
    Still have issues with asset_tracker, but I'll play with it some more now that I know that you have to poke the application to get it to run.
    Is there anything more I can do with mqtt_simple?  Otherwise, I'll look into modifying this code to communicate with the 64Seconds mqtt_server.
    I appreciate all the help in getting me this far.
    If you can point me to any documents which discuss modifying mqtt_simple to be used in other applications or have any suggestions to get me started, I welcome all help.
    Thank you again.
    -Craig Goldman
  • Hi Craig,
    From the logs that you posted, it seems that your modem firmware is quite old.
    Could you please download the latest one from here:
    https://www.nordicsemi.com/Products/Low-power-cellular-IoT/nRF9160/Download#infotabs
    And try the mqtt_simple example again?
    Håkon
  • Sorry if this is a duplicate post, my previous reply a few minutes ago seems to have disappeared.
    Followed instructions and encountered problems.
    First, instructions call for command of "pip install nrf9160_mdm_dfu-0.10.1+dev-py3-none-any.whl", but the fie included in the download is "nrf9160_mdm_dfu-0.10.0+dev-py3-none-any.whl"
    Second, after I install, I run the following and get errors....
    c:\SwTools\Nordic Semi\2019-06-25 nRF9160 Modem Update>nrf9160_mdm_dfu --update
      File "c:\python37\lib\runpy.py", line 193, in _run_module_as_main
        "__main__", mod_spec)
      File "c:\python37\lib\runpy.py", line 85, in _run_code
        exec(code, run_globals)
      File "C:\Python37\Scripts\nrf9160_mdm_dfu.exe\__main__.py", line 9, in <module>
      File "c:\python37\lib\site-packages\nrf9160_mdm_dfu\bin\nrf9160_mdm_dfu.py", line 24, in main
        nrf_dfu = nrf_dfu_API.nrf_dfu_API(quiet=args.quiet)
      File "c:\python37\lib\site-packages\nrf9160_mdm_dfu\api\nrf_dfu_API.py", line 37, in __init__
        self.api = API.API("NRF91")
      File "c:\python37\lib\site-packages\pynrfjprog\API.py", line 375, in __init__
        jlink_arm_dll_path = JLink.find_latest_dll()
      File "c:\python37\lib\site-packages\pynrfjprog\JLink.py", line 31, in find_latest_dll
        for root, dirs, files in os.walk(os.path.join(_DEFAULT_SEGGER_ROOT_PATH, jlink_sw_dirs[-1])):
    IndexError: list index out of range
    Any thoughts about what went wrong?
    Could it be that the download included "nrf9160_mdm_dfu-0.10.0+dev-py3-none-any.whl" but should have included "nrf9160_mdm_dfu-0.10.1+dev-py3-none-any.whl"?
    -Craig Goldman
  • Hi Craig,
    It looks like it cannot find your segger installation.
    Could you try downloading the latest driver from here, and see if that works?
    https://www.segger.com/downloads/jlink/
    Regarding the readme.txt, I'll report this internally. This should not have an impact on the modem upgrade procedure.
    Håkon
