Efficient Dynamic Advertising Message
We are implementing a small battery powered BLE advertiser using the nRF51822 with an odd requirement that the advertising data needs to change between each advertisement.
Our current approach is to create a timer with the same duration as the advertising interval, and in the timer_timeout_handler modify the advertising data using the ble_advdata_set call. This works almost all of the time, but because the actual advertising timer is buried in the BLE stack, it is essentially asynchronous relative to our timer leaving to the occasional cycle where the same data will be sent twice, or the advertising data will be updated a second time before it transmits.
Additionally, it seems like there will be a small power overhead cost incurred to wake the chip up and update the advdata when that doesn't happen at the same time as the advertisement, though this may be less of a concern then I am thinking. We are working off a coin cell, so every drop counts.
What I would like to do is move the ble_advdata_set call to the ble event handler and have it update the advdata in an event driven fashion. We currently have a ble event handler registered, I just don't know if there is an event I can hook to that will achieve what we are looking for. It could be something that is called right before a broadcast, or immediately after, just something that is called every time an advertising packet is sent out.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    ble_advdata_t newAdvData;
            newAdvData = generateNewData();
            ble_advdata_set(&newAdvData, NULL);
Thanks!
  • I haven't tried it, but have you looked into trying to use the Radio Notification feature to tell you when the radio is in, and not in, use. It's a little indirect but if all you're doing is advertising that should tell you every time that the radio has pumped out your previous advertisement and it's time to change the data.
  • Don't see how that would be applicable here. That's the callback you get when you've advertised for the lengthy of time you set in the start call without connection and advertising has then been stopped. For constant advertising that parameter is usually set to zero, in fact apart from limited advertising it's usually set to zero, so you never get that callback. The original poster is looking for a per advertising event callback.
  • Dear RK instead of using separate timer you can set timeout to 1sec for example and change your adv data on BLE_GAP_EVT_TIMEOUT event, then start adv again.
    Jeremy: you have to transfer adv on each channel few times before changing data to make it possible to receive by observer. To avoid duplicates just add counter field to your data so receiver can filter unique samples.
  • buslik: I feel like this could work, but unfortunately it looks like the timeout parameter in ble_gap_adv_params_t only accepts values in whole seconds. We are advertising faster than that so unfortunately this isn't a solution for us. Thanks for the input though!
