RNG interrupt handler not called
RNG interrupt handler is not called.
Using nrfx_rng library to generate random numbers.
VALRDY event is generated but interrupt handler nrfx_rng_irq_handler in library is not called.
Breakpoint not hit.
Despite EVENTS_VALRDY being set.
and INTENSET/ NVIC_ISER0 having correct values.
Code which sets up RNG using nrfx_rng library
ren_status_t generateRand(uint8_t * p_challenge)
ren_status_t return_value = RAND_ERROR;
static const nrfx_rng_config_t RNG_CONFIG = {
.error_correction = true,
.interrupt_priority = RNG_INTERRUPT_PRIORITY
assert(p_challenge != NULL);
challenge_pointer = p_challenge;
/* Reset random number counter. */
random_number_index = 0U;
/* Initialise random number generator. */
if (NRF_SUCCESS == nrfx_rng_init(&RNG_CONFIG, randomNumberEventHandler))
/* Start random number generator. */
nrfx_rng_start();
/* Wait for required number of random numbers to be generated. */
while(random_number_index < RAND_SIZE);
/* Stop random number generator. */
nrfx_rng_stop();
/* Uninitialise random number generator. */
nrfx_rng_uninit();
return_value = RAND_SUCCESS;
return return_value;
static void randomNumberEventHandler(uint8_t rng_data)
assert(challenge_pointer != NULL);
/* Store random number in appropriate location in challenge. */
rand_pointer[random_number_index] = rng_data;
/* Move on to next location. */
random_number_index++;
Any ideas ?
    I assume \nRF5_SDK_15.3.0_59ac345\examples\peripheral\rng\ can be used as reference, just make sure that you define SOFTDEVICE_PRESENT if used with the softdevice.
    Kenneth
  • In the end, as this is a relatively simple peripheral, I decided to access the hardware directly. Works fine.
    void generateRandomNumbers(uint8_t * p_random_numbers)
       assert(p_random_numbers != NULL);
       random_number_pointer = p_random_numbers;
       /* Configure for bias correction. */
       NRF_RNG->CONFIG = RNG_CONFIG_DERCEN_Enabled << RNG_CONFIG_DERCEN_Pos;
       /* Enable value ready interrupt. */
       sd_nvic_EnableIRQ(RNG_IRQn);
       NRF_RNG->INTENSET = RNG_INTENSET_VALRDY_Enabled << RNG_INTENSET_VALRDY_Pos;
       /* Start random number generation. */
       NRF_RNG->TASKS_START = 1U;
       while(random_number_index < CHALLENGE_LEN);
       NRF_RNG->TASKS_STOP = 1U;
    void RNG_IRQHandler(void)
       /* Random value ready. */
       /* Clear event. */
       NRF_RNG->EVENTS_VALRDY = 0U;
       random_number_pointer[random_number_index] = NRF_RNG->VALUE;
    I seem to have a similar issue with the RNG. I am not using the SoftDevice but it seems that the RNG does not run the interrupt function no matter what priotity I give it.
    The issue is when waiting for the RNG to generate the correct number of numbers.
    Using while(random_number_index < len) {}; does not work, while nrf_delay_ms(1); does!
    NRFX:
    static int random_number_index;
    static uint8_t *random_number_buf_ptr;
    static int random_number_max_len;
    void rng_event_handler(uint8_t rng_data)
        if (random_number_index < random_number_max_len)
            random_number_buf_ptr[random_number_index] = rng_data;
    int mcu_rng_generate(int len, uint8_t *rng_buf)
        // Reset random number counter
        random_number_index = 0;
        // Setup safety so that RNG does not fill up buffer beyound len
        random_number_max_len = len;
        random_number_buf_ptr = rng_buf;
        // Start random number generator
        nrfx_rng_start();
        // Wait for required number of random numbers to be generated
        // nrf_delay_ms(1); // <-- THIS WORKS
        while(random_number_index < len) {}; // <-- THIS DOES NOT WORK
        // NRF_LOG_INFO("%d < %d", random_number_index, len);
        // Stop random number generator
        nrfx_rng_stop();
        return NRF_SUCCESS;
    // Random number generator
    int mcu_rng_init()
        // Initialise random number generator
        nrfx_rng_config_t config = NRFX_RNG_DEFAULT_CONFIG;
        return nrfx_rng_init(&config, rng_event_handler);
    Same thing when using the HW registers directly:
        NRFX_IRQ_PRIORITY_SET(RNG_IRQn, 6);
        NRFX_IRQ_ENABLE(RNG_IRQn);
        while(random_number_index < len); <-- THIS DOES NOT WORK!
        return NRF_SUCCESS;
        // Clear event
            random_number_buf_ptr[random_number_index] = NRF_RNG->VALUE;
    I have tried setting the NRFX_IRQ_PRIORITY_SET(RNG_IRQn, 6); to different things (0 and 12) but no difference.
    Can anybody help explaining what nrf_delay_ms(1); does differently than the busy-waiting version?
    Kind regards
    the compiler optimizes (throws away) your busy-wait loop because it has no idea that random_number_index may change outside of this loop. Try to define random_number_index as volatile.
