Lighting switch and Ble_app_uart examples simultaneously (nRF52840, pca10056, s140, SDK 15.3.0, Mesh 3.1.0)
I work with an nRF52840 DK and I want to put together the "Light switch" application with the "BLE_app_uart" application . I use the S140 softdevice, SDK 15.3.0 and version 3.1.0 of the mesh for this purpose.
For this I was inspired by this post: https://devzone.nordicsemi.com/f/nordic-q-a/29108/how-to-add-mesh-into-nrf5-sdk-v14-1-v15-ble-application , and also the example "ble_app_uart_coexist" which seems to do this, but only for nRF52832, s132, pca10040.
Currently I can operate the two codes "Light switch" and "ble_app_uart" separately, simply and only replacing the necessary code in the main.c file.
Now the problem comes when I want to run the BLE and mesh together. When I launch the application. I then get a following error message:
app_error_weak.c, 119, Mesh error 4 at 0x000000000000 (:0)
However, I added the following lines at the beginning of my code :
static void mesh_soc_evt_handler(uint32_t evt_id, void * p_context)
nrf_mesh_on_sd_evt(evt_id);
NRF_SDH_SOC_OBSERVER(m_mesh_soc_observer, 0, mesh_soc_evt_handler, NULL);
Despite this, it is impossible to run the BLE and mesh together.
How can I get my code to work correctly?
I have attached the corresponding code to you.
server_BLE_Peripheral.zip
Thank you in advance for your help!
Maxime
