LPCOMP issue with sensing multiple inputs
I'm using LPCOMP to sense multiple input.
I call the lpcomp_read() function below for each input pin.
If I only call this function for 1 pin only, it worked fine.
For example:
read_value  |= lpcomp_read(4) << 1; <== this would return read_value = 2, and that is correct.
However, when I call this function multiple times for multiple pins, it only read the 1st one as if the PSEL stuck on the 1st pin.
read_value |= lpcomp_read(2) << 0;
I expected read_value to be 3 (as both pins should be above reference voltage). Instead, I always get read_value = 1;
Is there any clearing of the LPCOMP if I want to use it again for another pin?
uint32_t lpcomp_read (uint32_t analog_pin)
uint32_t lpcomp_result;
NRF_LPCOMP_Type NRT_LPCOMP;
//Set Reference Voltage to VDD *2/8
NRF_LPCOMP->REFSEL |= (LPCOMP_REFSEL_REFSEL_SupplyTwoEighthsPrescaling << LPCOMP_REFSEL_REFSEL_Pos);
NRF_LPCOMP->PSEL = (analog_pin << LPCOMP_PSEL_PSEL_Pos);
//Enable LPCOMP
NRF_LPCOMP->ENABLE = LPCOMP_ENABLE_ENABLE_Enabled;
//start LPCOMP
NRF_LPCOMP->TASKS_START = 1;
while (!NRF_LPCOMP->EVENTS_READY) {}
//Sample Comparator Value
NRF_LPCOMP->TASKS_SAMPLE = 1;
//reset result
lpcomp_result = NRF_LPCOMP->RESULT;
//stop LPCOMP
NRF_LPCOMP->TASKS_STOP = 1;
//Disable LPCOMP
NRF_LPCOMP->ENABLE = LPCOMP_ENABLE_ENABLE_Disabled;
//return result
return lpcomp_result;
