Problems with ZigBee SDK
I am using nrf52840 module with a kit that i built by myself. The kit is working because i am able to flash and debug without problems.
I am using Segger embedded studio.
I am trying to understand the sdk, so i tried with light bulb example, but it always stucks on the function zboss_main_loop_iteration() in the while loop (I knew it, doing a debug for the program) but when i tried to enter to that function, the ide didn't find the definition of the function. The same case happened with many functions. I want to know if their source is closed or it's me that i have built the toolchain in wrong way?
The main goal was to test the light bulb with Alexa Eco Plus using Zigbee, but Alexa didn't recognize anything.
Thanks
    Yes, our Zigbee stack uses ZBOSS 3.0 stack which is closed source. All our examples use channel 16 as default, so you need a coordinator listening on that channel for the device to join a network. Most probably the Echo Plus has already created a network using another channel.
    If you have a nRF52840 dongle you can use it as a sniffer to check in which channel the network is located, and you can change ZIGBEE_CHANNEL in the example for the right one.
    Marjeris
