How to handle at command in nRF9160?
I want to handle at command in main.c file. How can you do it?
For example, how can you send "AT+COPS?" and received return value?
I tested simple_at program below, but it doesn't work.
https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/simple_at
Peripheral              Domain          Status
00 NRF_P0               Non-Secure      OK
01 NRF_CLOCK            Non-Secure      OK
02 NRF_RTC1             Non-Secure      OK
03 NRF_NVMC             Non-Secure      OK
04 NRF_UARTE1           Non-Secure      OK
05 NRF_UARTE2           Secure          SKIP
06 NRF_IPC              Non-Secure      OK
07 NRF_VMC              Non-Secure      OK
08 NRF_FPU              Non-Secure      OK
09 NRF_EGU1             Non-Secure      OK
10 NRF_EGU2             Non-Secure      OK
11 NRF_TWIM2            Non-Secure      OK
12 NRF_SPIM3            Non-Secure      OK
13 NRF_TIMER0           Non-Secure      OK
14 NRF_TIMER1           Non-Secure      OK
15 NRF_TIMER2           Non-Secure      OK
16 NRF_SAADC            Non-Secure      OK
17 NRF_GPIOTE1          Non-Secure      OK
SPM: NS image at 0x8000
SPM: NS MSP at 0x20022610
SPM: NS reset vector at 0x9efd
SPM: prepare to jump to Non-Secure image.
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x20020130
Faulting instruction address = 0x0
Fatal fault in ISR! Spinning...
Thanks
    Please have a look at the AT Client sample project. This allows you to send and receive AT commands in a terminal e.g. LTE Link Monitor.
    Øyvind
  • Thank you for your reply.
    I've already checked the at client sample.
    github.com/.../at_client
    I don't see code to send at command in main.c.
    Can u tell me which lines send at command?
  • Sorry, I misread your initial question. I thought you just needed a way to send and receive AT commands.
    The AT_client sample uses threads in Zephyr OS to handle AT commands.
    To solve the hard fault issue, please try to add the following in the prj.conf file:
    CONFIG_MAIN_STACK_SIZE=4096
    Thanks!
    Øyvind
  • Thanks so much! It works out!
    Can I ask one more question?
    I want to send MNC and MNN data of LTE cell station through MQTT so that I'm trying to integrate mqtt_simple and simple_at programs.
    https://github.com/NordicPlayground/fw-nrfconnect-nrf/tree/master/samples/nrf9160/mqtt_simple
    You can get MNC and MNN data by "AT+COPS?" command.
    Compared to mqtt_simple prj.conf file, simple_at program additionally includes these three settings in prj.conf file.
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NET_BUF_USER_DATA_SIZE=1
    CONFIG_NET_RAW_MODE=y
    I omitted these lines in prj.conf and integrated the two programs. It works out, but I'm suspicious that I might do wrong coding. What do you think about this? I'm not familiar with network communication side.
    Full code is below. app_socket_start() is added after fds_init().
    Thanks.
    <prj.conf>
    # General config
    CONFIG_TEST_RANDOM_GENERATOR=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # BSD library
    CONFIG_BSD_LIBRARY=y
    # AT Host
    CONFIG_AT_HOST_LIBRARY=y
    # MQTT
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LIB_TLS=n
    # Appliaction
    CONFIG_MQTT_PUB_TOPIC="myPubTopic"
    CONFIG_MQTT_SUB_TOPIC="mySubTopic"
    CONFIG_MQTT_CLIENT_ID="myClientID"
    CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxxxxxxxxxxxxxxxxx"
    CONFIG_MQTT_BROKER_PORT=1883
    # Main thread
    CONFIG_MAIN_THREAD_PRIORITY=7
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    # CONFIG_STDOUT_CONSOLE=y
    # CONFIG_NET_BUF_USER_DATA_SIZE=1
    # CONFIG_NET_RAW_MODE=y
     * Copyright (c) 2018 Nordic Semiconductor ASA
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    #include <zephyr.h>
    #include <stdio.h>
    #include <uart.h>
    #include <string.h>
    #include <net/mqtt.h>
    #include <net/socket.h>
    #include <lte_lc.h>
    #define MQTT_USERNAME "username"
    #define MQTT_PASSWORD "password"
    /* Buffers for MQTT client. */
    static u8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
    static u8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
    static u8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
    /* The mqtt client struct */
    static struct mqtt_client client;
    /* MQTT Broker details. */
    static struct sockaddr_storage broker;
    /* Connected flag */
    static bool connected;
    /* File descriptor */
    static struct pollfd fds;
    #if defined(CONFIG_BSD_LIBRARY)
    /**@brief Recoverable BSD library error. */
    void bsd_recoverable_error_handler(uint32_t err)
    	printk("bsdlib recoverable error: %u\n", err);
    /**@brief Irrecoverable BSD library error. */
    void bsd_irrecoverable_error_handler(uint32_t err)
    	printk("bsdlib irrecoverable error: %u\n", err);
    	__ASSERT_NO_MSG(false);
    #endif /* defined(CONFIG_BSD_LIBRARY) */
    /**@brief Function to print strings without null-termination
    static void data_print(u8_t *prefix, u8_t *data, size_t len)
    	char buf[len + 1];
    	memcpy(buf, data, len);
    	buf[len] = 0;
    	printk("%s%s\n", prefix, buf);
    /**@brief Function to publish data on the configured topic
    static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
    	struct mqtt_publish_param param;
    	param.message.topic.qos = qos;
    	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
    	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
    	param.message.payload.data = data;
    	param.message.payload.len = len;
    	param.message_id = sys_rand32_get();
    	param.dup_flag = 0;
    	param.retain_flag = 0;
    	data_print("Publishing: ", data, len);
    	printk("to topic: %s len: %u\n",
    		CONFIG_MQTT_PUB_TOPIC,
    		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
    	return mqtt_publish(c, &param);
    /**@brief Function to subscribe to the configured topic
    static int subscribe(void)
    	struct mqtt_topic subscribe_topic = {
    		.topic = {
    			.utf8 = CONFIG_MQTT_SUB_TOPIC,
    			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
    		.qos = MQTT_QOS_1_AT_LEAST_ONCE
    	const struct mqtt_subscription_list subscription_list = {
    		.list = &subscribe_topic,
    		.list_count = 1,
    		.message_id = 1234
    	printk("Subscribing to: %s len %u\n", CONFIG_MQTT_SUB_TOPIC,
    		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
    	return mqtt_subscribe(&client, &subscription_list);
    /**@brief Function to read the published payload.
    static int publish_get_payload(struct mqtt_client *c, size_t length)
    	u8_t *buf = payload_buf;
    	u8_t *end = buf + length;
    	if (length > sizeof(payload_buf)) {
    		return -EMSGSIZE;
    	while (buf < end) {
    		int ret = mqtt_read_publish_payload(c, buf, end - buf);
    		if (ret < 0) {
    			int err;
    			if (ret != -EAGAIN) {
    				return ret;
    			printk("mqtt_read_publish_payload: EAGAIN\n");
    			err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
    			if (err > 0 && (fds.revents & POLLIN) == POLLIN) {
    				continue;
    			} else {
    				return -EIO;
    		if (ret == 0) {
    			return -EIO;
    		buf += ret;
    	return 0;
    /**@brief MQTT client event handler
    void mqtt_evt_handler(struct mqtt_client *const c,
    		      const struct mqtt_evt *evt)
    	int err;
    	switch (evt->type) {
    	case MQTT_EVT_CONNACK:
    		if (evt->result != 0) {
    			printk("MQTT connect failed %d\n", evt->result);
    		connected = true;
    		printk("[%s:%d] MQTT client connected!\n", __func__, __LINE__);
    		subscribe();
    	case MQTT_EVT_DISCONNECT:
    		printk("[%s:%d] MQTT client disconnected %d\n", __func__,
    		       __LINE__, evt->result);
    		connected = false;
    	case MQTT_EVT_PUBLISH: {
    		const struct mqtt_publish_param *p = &evt->param.publish;
    		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
    		       __LINE__, evt->result, p->message.payload.len);
    		err = publish_get_payload(c, p->message.payload.len);
    		if (err >= 0) {
    			data_print("Received: ", payload_buf,
    			/* Echo back received data */
    			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
    				payload_buf, p->message.payload.len);
    		} else {
    			printk("mqtt_read_publish_payload: Failed! %d\n", err);
    			printk("Disconnecting MQTT client...\n");
    			err = mqtt_disconnect(c);
    			if (err) {
    				printk("Could not disconnect: %d\n", err);
    	} break;
    	case MQTT_EVT_PUBACK:
    			printk("MQTT PUBACK error %d\n", evt->result);
    		printk("[%s:%d] PUBACK packet id: %u\n", __func__, __LINE__,
    				evt->param.puback.message_id);
    	case MQTT_EVT_SUBACK:
    			printk("MQTT SUBACK error %d\n", evt->result);
    		printk("[%s:%d] SUBACK packet id: %u\n", __func__, __LINE__,
    				evt->param.suback.message_id);
    		printk("[%s:%d] default: %d\n", __func__, __LINE__,
    				evt->type);
    /**@brief Resolves the configured hostname and
     * initializes the MQTT broker structure
    static void broker_init(void)
    	int err;
    	struct addrinfo *result;
    	struct addrinfo *addr;
    	struct addrinfo hints = {
    		.ai_family = AF_INET,
    		.ai_socktype = SOCK_STREAM
    	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
    	if (err) {
    		printk("ERROR: getaddrinfo failed %d\n", err);
    		return;
    	addr = result;
    	err = -ENOENT;
    	/* Look for address of the broker. */
    	while (addr != NULL) {
    		/* IPv4 Address. */
    		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
    			struct sockaddr_in *broker4 =
    				((struct sockaddr_in *)&broker);
    			broker4->sin_addr.s_addr =
    				((struct sockaddr_in *)addr->ai_addr)
    				->sin_addr.s_addr;
    			broker4->sin_family = AF_INET;
    			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
    			printk("IPv4 Address found 0x%08x\n",
    				broker4->sin_addr.s_addr);
    		} else {
    			printk("ai_addrlen = %u should be %u or %u\n",
    				(unsigned int)addr->ai_addrlen,
    				(unsigned int)sizeof(struct sockaddr_in),
    				(unsigned int)sizeof(struct sockaddr_in6));
    		addr = addr->ai_next;
    	/* Free the address. */
    	freeaddrinfo(result);
    /**@brief Initialize the MQTT client structure
    static void client_init(struct mqtt_client *client)
    	mqtt_client_init(client);
    	broker_init();
        static struct mqtt_utf8 password;
    	static struct mqtt_utf8 user_name;
    	password.utf8 = (u8_t*)MQTT_PASSWORD;
    	password.size = strlen(MQTT_PASSWORD);
    	user_name.utf8 = (u8_t*)MQTT_USERNAME;
    	user_name.size = strlen(MQTT_USERNAME);
    	/* MQTT client configuration */
    	client->broker = &broker;
    	client->evt_cb = mqtt_evt_handler;
    	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
    	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
    	client->password = &password;
    	client->user_name = &user_name;
    	client->protocol_version = MQTT_VERSION_3_1_1;
    	/* MQTT buffers configuration */
    	client->rx_buf = rx_buffer;
    	client->rx_buf_size = sizeof(rx_buffer);
    	client->tx_buf = tx_buffer;
    	client->tx_buf_size = sizeof(tx_buffer);
    	/* MQTT transport configuration */
    	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
    /**@brief Initialize the file descriptor structure used by poll.
    static int fds_init(struct mqtt_client *c)
    	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
    		fds.fd = c->transport.tcp.sock;
    	} else {
    #if defined(CONFIG_MQTT_LIB_TLS)
    		fds.fd = c->transport.tls.sock;
    #else
    		return -ENOTSUP;
    	fds.events = POLLIN;
    	return 0;
    /**@brief Configures modem to provide LTE link. Blocks until link is
     * successfully established.
    static void modem_configure(void)
    #if defined(CONFIG_LTE_LINK_CONTROL)
    	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
    		/* Do nothing, modem is already turned on
    		 * and connected.
    	} else {
    		int err;
    		printk("LTE Link Connecting ...\n");
    		err = lte_lc_init_and_connect();
    		__ASSERT(err == 0, "LTE link could not be established.");
    		printk("LTE Link Connected!\n");
    #define RECV_BUF_SIZE 1024
    char recv_buf[RECV_BUF_SIZE + 1];
    const char *at_commands[] = {
    	"AT+COPS?"
    	/* Add more here if needed */
    int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
    	int err;
    	do {
    		err = recv(fd, buf, size, flags);
    	} while (err < 0 && errno == EAGAIN);
    	return err;
    int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags)
    	int err;
    	do {
    		err = send(fd, buf, size, flags);
    	return err;
    int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len)
    	int err;
    	do {
    		err = connect(fd, local_addr, len);
    	return err;
    void app_socket_start(void)
    	int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
    	printk("Starting simple AT socket application\n\r");
    	if (at_socket_fd < 0) {
    		printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
    	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
    		int bytes_written = send(at_socket_fd, at_commands[i],
    					 strlen(at_commands[i]), 0);
    		if (bytes_written > 0) {
    			int r_bytes =
    				blocking_recv(at_socket_fd, recv_buf,
    					      sizeof(recv_buf), MSG_DONTWAIT);
    			if (r_bytes > 0) {
    				printk("%s", recv_buf);
    	printk("Closing socket\n\r");
    	(void)close(at_socket_fd);
    void main(void)
    	int err;
    	printk("The MQTT simple sample started\n");
    	modem_configure();
    	client_init(&client);
    	err = mqtt_connect(&client);
    	if (err != 0) {
    		printk("ERROR: mqtt_connect %d\n", err);
    		return;
    	err = fds_init(&client);
    	if (err != 0) {
    		printk("ERROR: fds_init %d\n", err);
    		return;
    	while (1) {
            app_socket_start(); // ADD HERE
    		if (err < 0) {
    			printk("ERROR: poll %d\n", errno);
    		err = mqtt_live(&client);
    		if (err != 0) {
    			printk("ERROR: mqtt_live %d\n", err);
    		if ((fds.revents & POLLIN) == POLLIN) {
    			err = mqtt_input(&client);
    			if (err != 0) {
    				printk("ERROR: mqtt_input %d\n", err);
    		if ((fds.revents & POLLERR) == POLLERR) {
    			printk("POLLERR\n");
    		if ((fds.revents & POLLNVAL) == POLLNVAL) {
    			printk("POLLNVAL\n");
    	err = mqtt_disconnect(&client);
    	if (err) {
    		printk("Could not disconnect MQTT client. Error: %d\n", err);
  • Hello again,
    Information about configuration options can be found here, in the Zephyr documentation.
    From the description given in the documentation, I don't see any problems if it works. I have not tested this myself, so if you meet any issues, please let me know.
    Øyvind
