The Jlink RTT Viewer can't output the message one by one , some was lost , what is the problem? (Jink connect by SWD 4000khz)
Are you using NRF_LOG to output logs to RTT? Which SDK version are you using? There are some configs in sdk_config.h related to NRF_LOG and RTT buffer sizes, and behavior with buffer overflow. Do you send large amounts of logs in short time?
Jørgen
Yes,I using NRF_LOG_INFO to output logs to RTT in SDK 15.0 .
In sdk_config.h, I had set
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 2048 ;
#define NRF_LOG_BUFSIZE 2048
#define NRF_LOG_MSGPOOL_ELEMENT_COUNT 18
I send about 20-40 lines logs on startup,some was lost
Can you try setting SEGGER_RTT_CONFIG_DEFAULT_MODE to 2 (BLOCK_IF_FIFO_FULL)?
