The image is a little small, could you upload a larger one please, so we might be able to see the details?
Andreas
let me know if i need to make any changes .
i have another design which is exact copy of sparkfun design.if you flag up i will go for pcb printing withadding up some component.
if you need any other file please let me know.
i am really grateful for your help but i need quick assistance.
thanks and regards
The design looks good. Usually you can get a little better harmonics by grounding C28 to the center pad through pin 31, instead of to the ground pour. You might also want to add a shunt component(DNP at this time) near the antenna feed in case the antenna requires tuning.
Andreas
Hi Andreas
what should i do for antenna tuning?
Should i apply silk screen over antenna feed?
Is my design will be best if i use Johnson ceramic antenna and matching chip.
kindly suggest me how to proceed.
See this document on antenna tuning. We can also help with this if you send the PCB to us.
A printed antenna is always preferred over a ceramic chip antenna provided you have space enough to accomodate it. They are generally better, easier/cheaper(less components) to tune and no extra BOM cost for the antenna itself.
Andreas
