Multitouch Usb to Hid over bluetooth
Hey guys, i recently bought a nrf52 DK to implement a gateway between a usb touch monitor to a device such as a android or a computer.my approach is recovering the hid raw frame  with a raspberry pi and send it by uart to the bluetooth module, and put it in the data struture correspondent and send it as hid examples in SDK.
I can now receive hid raw frame in the nrf52DK as an char array as you can see in the following picture. My code is an adapted code of the uart example of the last SDK, its receiving 124char corresponding to 62byte data frame of my usb hid frame.
This is my data struture that i got with an hid tool
// Digitizer Device Page featureReport 02 (Device <-> Host)
typedef struct
  uint8_t  reportId;                                 // Report ID = 0x02 (2)
                                                     // Collection: CA:TouchScreen
  uint8_t  DIG_TouchScreenContactCountMaximum;       // Usage 0x000D0055: Contact Count Maximum, Value = 0 to 10
} featureReport02_t;
// Digitizer Device Page inputReport 02 (Device --> Host)
typedef struct inputReport02_t
                                                     // Collection: CA:TouchScreen CL:Finger
  uint8_t  DIG_TouchScreenFingerTipSwitch : 1;       // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenFingerInRange : 1;         // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenFingerConfidence : 1;      // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenFingerContactIdentifier;   // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenFingerX;                    // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenFingerY;                    // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch : 1;             // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange : 1;               // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence : 1;            // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier;         // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX;                          // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY;                          // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_1 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_1 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_1 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_1;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_1;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_1;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_2 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_2 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_2 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_2;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_2;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_2;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_3 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_3 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_3 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_3;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_3;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_3;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_4 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_4 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_4 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_4;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_4;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_4;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_5 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_5 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_5 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_5;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_5;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_5;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_6 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_6 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_6 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_6;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_6;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_6;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_7 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_7 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_7 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_7;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_7;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_7;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_8 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_8 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_8 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_8;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_8;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_8;                        // Usage 0x00010031: Y, Value = 0 to 32767
  uint8_t  DIG_TouchScreenTipSwitch_9 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_9 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_9 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_9;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_9;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_9;
  uint8_t  DIG_TouchScreenTipSwitch_10 : 1;           // Usage 0x000D0042: Tip Switch, Value = 0 to 1
  uint8_t  DIG_TouchScreenInRange_10 : 1;             // Usage 0x000D0032: In Range, Value = 0 to 1
  uint8_t  DIG_TouchScreenConfidence_10 : 1;          // Usage 0x000D0047: Confidence, Value = 0 to 1
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  : 1;                                      // Pad
  uint8_t  DIG_TouchScreenContactIdentifier_10;       // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
  uint16_t GD_TouchScreenX_10;                        // Usage 0x00010030: X, Value = 0 to 32767
  uint16_t GD_TouchScreenY_10;
  uint8_t  DIG_TouchScreenContactCount;              // Usage 0x000D0054: Contact Count, Value = 0 to 32767
} inputReport02_t;
and this is my hex file
// Decoded Application Collection
05 0D        (GLOBAL) USAGE_PAGE         0x000D Digitizer Device Page
09 04        (LOCAL)  USAGE              0x000D0004 Touch Screen (Application Collection)
A1 01        (MAIN)   COLLECTION         0x01 Application (Usage=0x000D0004: Page=Digitizer Device Page, Usage=Touch Screen, Type=Application Collection)
85 02          (GLOBAL) REPORT_ID          0x02 (2)
09 22          (LOCAL)  USAGE              0x000D0022 Finger (Logical Collection)
A1 02          (MAIN)   COLLECTION         0x02 Logical (Usage=0x000D0022: Page=Digitizer Device Page, Usage=Finger, Type=Logical Collection)
05 0D            (GLOBAL) USAGE_PAGE         0x000D Digitizer Device Page <-- Redundant: USAGE_PAGE is already 0x000D
09 42            (LOCAL)  USAGE              0x000D0042 Tip Switch (Momentary Control)
15 00            (GLOBAL) LOGICAL_MINIMUM    0x00 (0)  <-- Info: Consider replacing 15 00 with 14
25 01            (GLOBAL) LOGICAL_MAXIMUM    0x01 (1)
75 01            (GLOBAL) REPORT_SIZE        0x01 (1) Number of bits per field
95 01            (GLOBAL) REPORT_COUNT       0x01 (1) Number of fields
81 02            (MAIN)   INPUT              0x00000002 (1 field x 1 bit) 0=Data 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap
09 32            (LOCAL)  USAGE              0x000D0032 In Range (Momentary Control)
09 47            (LOCAL)  USAGE              0x000D0047 Confidence (Dynamic Value)
95 05            (GLOBAL) REPORT_COUNT       0x05 (5) Number of fields
81 03            (MAIN)   INPUT              0x00000003 (5 fields x 1 bit) 1=Constant 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap
75 08            (GLOBAL) REPORT_SIZE        0x08 (8) Number of bits per field
09 51            (LOCAL)  USAGE              0x000D0051 Contact Identifier (Dynamic Value)
81 02            (MAIN)   INPUT              0x00000002 (1 field x 8 bits) 0=Data 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap
05 01            (GLOBAL) USAGE_PAGE         0x0001 Generic Desktop Page
15 00            (GLOBAL) LOGICAL_MINIMUM    0x00 (0) <-- Redundant: LOGICAL_MINIMUM is already 0 <-- Info: Consider replacing 15 00 with 14
26 FF7F          (GLOBAL) LOGICAL_MAXIMUM    0x7FFF (32767)
75 10            (GLOBAL) REPORT_SIZE        0x10 (16) Number of bits per field
09 30            (LOCAL)  USAGE              0x00010030 X (Dynamic Value)
81 02            (MAIN)   INPUT              0x00000002 (1 field x 16 bits) 0=Data 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap
09 31            (LOCAL)  USAGE              0x00010031 Y (Dynamic Value)
C0             (MAIN)   END_COLLECTION     Logical
A1 02          (MAIN)   COLLECTION         0x02 Logical (Usage=0x0: Page=, Usage=, Type=) <-- Error: COLLECTION must be preceded by a USAGE <-- Warning: USAGE type should be CL (Logical Collection)
95 01            (GLOBAL) REPORT_COUNT       0x01 (1) Number of fields <-- Redundant: REPORT_COUNT is already 1
09 54          (LOCAL)  USAGE              0x000D0054 Contact Count (Dynamic Value)
81 02          (MAIN)   INPUT              0x00000002 (1 field x 8 bits) 0=Data 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap  <-- Error: REPORT_SIZE (8) is too small for LOGICAL_MAXIMUM (32767) which needs 15 bits.
09 55          (LOCAL)  USAGE              0x000D0055 Contact Count Maximum (Static Value)
25 0A          (GLOBAL) LOGICAL_MAXIMUM    0x0A (10)
B1 02          (MAIN)   FEATURE            0x00000002 (1 field x 8 bits) 0=Data 1=Variable 0=Absolute 0=NoWrap 0=Linear 0=PrefState 0=NoNull 0=NonVolatile 0=Bitmap
C0           (MAIN)   END_COLLECTION     Application
but now my problem is: how to "fill" my data structure with the data that i'm receiving?
  • Hi
    I am a bit confused looking at the struct, and comparing it to the numbers you mention (124 char's and 62 byte data frame).
    Correct me if I'm wrong, but the struct sets up 12 similar value groups, each 6 bytes in size (3 one bit values, 5 bits of padding, a one byte contact identifier and two bytes each for X and Y).
    Then at the end there is one additional byte, which means the full struct should be 12*6 + 1 = 73 bytes in size.
    Are there too many touch points defined in the descriptor?
    Do you have an overview of the content of the 124 char UART packet that you are receiving?
    From the numbers alone it is hard to see how this should match the data structure that you included.
    Best regards
    Torbjørn
  • Dear Torbjørn,
    Thank you for quick reply. You're right, the descriptor is wrong.
    Now we have
    1byte for report id
    1byte (3bit value + 5 bis of padding)
    2byte x value
    2byte y value
    1 contact identifier byte
    1byte contact counter
    1byte + (1+2+2+1)byte*10 + 1byte =  62 byte
    typedef struct
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerTipSwitch_1 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_1 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_1 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_1; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_1;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_1;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_2 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_2 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_2 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_2; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_2;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_2;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_3 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_3 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_3 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_3; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_3;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_3;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_4 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_4 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_4 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_4; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_4;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_4;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_5 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_5 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_5 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_5; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_5;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_5;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_6 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_6 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_6 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_6; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_6;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_6;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_7 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_7 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_7 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_7; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_7;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_7;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_8 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_8 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_8 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_8; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_8;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_8;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenFingerTipSwitch_9 : 1;     // Usage 0x000D0042: Tip Switch, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerInRange_9 : 1;       // Usage 0x000D0032: In Range, Value = 0 to 1
      uint8_t  DIG_TouchScreenFingerConfidence_9 : 1;    // Usage 0x000D0047: Confidence, Value = 0 to 1
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  : 1;                                      // Pad
      uint8_t  DIG_TouchScreenFingerContactIdentifier_9; // Usage 0x000D0051: Contact Identifier, Value = 0 to 1
      uint16_t GD_TouchScreenFingerX_9;                  // Usage 0x00010030: X, Value = 0 to 32767
      uint16_t GD_TouchScreenFingerY_9;                  // Usage 0x00010031: Y, Value = 0 to 32767
      uint8_t  DIG_TouchScreenContactCount;              // Usage 0x000D0054: Contact Count, Value = 0 to 10
    } inputReport02_t;
    does it make more sense?
  • Attached is my code that i've been develop this afternoon. i've added data structure and hex hid descriptor and have 2 different pointer positions with the iteration with button0 or button1.
    I'm getting "
    <warning> app: System reset
    <error> app: Fatal error
    when connected by UART. ble_app_hids_mouse.zip
  • Hi
    This definitely makes more sense Slight smile
    Best regards
    Torbjørn
  • Hi
    Which SDK version did you use for the example?
    Have you tried running the debugger to trace which part of the code is triggering the fatal error?
    Best regards
    Torbjørn
