SAADC samples the same as ground value for LM35 sensor.
Hi, I'm running the saddc_pca10056 peripheral example given in SDK v15.2.0.
The analogue pin A0 is connected to the signal line of an LM35 temperature sensor. When I measure the voltage of the pin it increases from 300mV to 320mV when touched. The noise on the input of the ADC seems to be too much to detect this. I need the sensors to be very accurate as they will be detecting skin temperature during rodent testing for safety. I get a steady stream of values through and the input definitely works as it changes value when connected to the 5V line. Any ideas on what might need changing?
  • You should do three things:
    1. Run offset calibration on start-up, and every second degree Celsius change in temperature.
    2. Ensure that you've configured the SAADC to sample in the correct operating range of your signal. I suggest you try a gain of 1, and use the internal 0.6V reference.
    3. Enable oversampling of your measurement, at least 10X.
  • Hi, thank you for the suggestions:
    1. I added the offset calibration to start up, the values coming through average at about 80 for the first reading and then return to the usual values around 1900. For calibrating every second degree Celsius change in temperature: Firstly if the ADC can't detect the temperature change because of the noise how would you be able to trigger such an event? Secondly would this mean uninitialising and reinitialising the ADC? Running calibration will not work unless the ADC is idle
    2. This was already implemented before, forgot to mention.
    3. I tried 16x oversampling onwards along side a resolution of 14-bits (as is suggested in the documentation) and there was no difference in results apart from the expected slow down as oversampling increased.
    Thanks in advance :)
    *EDIT* - code followed by debug prints below
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nrf_adc_example main.c
     * @ingroup nrf_adc_example
     * @brief ADC Example Application main file.
     * This file contains the source code for a sample application using ADC.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SAMPLES_IN_BUFFER 5
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
        ret_code_t err_code;
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            int i;
            uint32_t data_average = 0;
            NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            SEGGER_RTT_printf(0, "ADC event: %d -> ", (int)m_adc_evt_counter); //swap for debug print
            for (i = 0; i < SAMPLES_IN_BUFFER; i++)
                NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
                SEGGER_RTT_printf(0,"%d:", p_event->data.done.p_buffer[i]); //swap for debug print
                data_average += p_event->data.done.p_buffer[i];
            //Produce average of the buffered data
            data_average = data_average/i+1;
            SEGGER_RTT_printf(0, " AVERAGE : %u\n", data_average);
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
        //calibrate on start up
        err_code = nrfx_saadc_calibrate_offset();
        SEGGER_RTT_printf(0, "Calibration Error Code %x\n", err_code);
        saadc_init();
        saadc_sampling_event_init();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    //----------debug print out from above main----------------//
    Calibration Error Code 0
    ADC event: 0 -> -69:319:130:33:-8: AVERAGE : 82
    ADC event: 1 -> 16:1849:1847:1845:1848: AVERAGE : 1482
    ADC event: 2 -> 1836:1858:1851:1852:1858: AVERAGE : 1852
    ADC event: 3 -> 1852:1842:1843:1840:1841: AVERAGE : 1844
    ADC event: 4 -> 1853:1849:1852:1841:1843: AVERAGE : 1848
    ADC event: 5 -> 1846:1852:1837:1845:1845: AVERAGE : 1846
    ADC event: 6 -> 1838:1845:1842:1847:1845: AVERAGE : 1844
    ADC event: 7 -> 1853:1839:1836:1848:1850: AVERAGE : 1846
    ADC event: 8 -> 1846:1838:1844:1852:1857: AVERAGE : 1848
    ADC event: 9 -> 1856:1850:1859:1855:1854: AVERAGE : 1855
    ADC event: 10 -> 1867:1860:1858:1854:1857: AVERAGE : 1860
    ADC event: 11 -> 1849:1858:1861:1845:1842: AVERAGE : 1852
  • I suggest you use the SAADC to measure a proper voltage source first. This will tell you if there's noise in the SAADC or if it's in the temperature sensor's signal.
    You should also check your power supply and make sure that you adhere to the reference design of the nRF52 and the temperature sensor's.
  • Measuring a proper bench voltage source varying it from 0-5V produced some strange results. Regardless of the configuration of the SAADC channel, reading only changed when input voltage exceeded 3.65V. This either maxed out the reading or put it within a range (depending on the gain and reference voltage) that is usable to detect voltage change from 3.7V+. Any ideas why this might be the case? It sounds like a hardware issue to me.
    I am using the development board so power is supplied by USB and taking the 0-5V rails to power the temperature sensor, it's a very simple sensor and the measured signal from that on both volt meter and oscilloscope comes out as expected.
  • What voltage is VDD at?
    You've probably exceeded the maximum rated voltage for the gpio, and consequently blown an ESD fuse.
    See I/O pin voltage in Absolute maximum ratings.
