nRF52832 uart doesn't work
Hi Team,
I transplant the project nRF5_SDK_14.2.0_17b948a\examples\peripheral\uart to the project ble_central\ble_app_multilink_central, uart doesn't work.
It indicate that :APP_UART_COMMUNICATION_ERROR.
Hope to receive your reply ,Thanks very much!
My email: [email protected]  [email protected]
operation refer:https://blog.csdn.net/saver_26/article/details/84526754
What I do is that:
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#include "app_uart.h"
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
void uart_write(uint8_t *pdata,uint8_t length)
    int i;
    for (i = 0; i < length; i++)
        UNUSED_VARIABLE(app_uart_put(*pdata++));
/**@brief   Function for handling app_uart events.
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t data_array[256];
//    static uint8_t index = 0;
//    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            UNUSED_VARIABLE(app_uart_get(&data_array[0]));
            uart_write(data_array,1);                            //可以根据需要修改对收到的数据的处理。
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
    uint32_t                     err_code;
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .rts_pin_no   = RTS_PIN_NUMBER,
        .cts_pin_no   = CTS_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
2,main函数里面加入初始化的调用。
3,增加或者修改配置文件里的宏定义
// <e> APP_UART_ENABLED - app_uart - UART driver
#ifndef APP_FIFO_ENABLED
#define APP_FIFO_ENABLED 1
#ifndef APP_UART_ENABLED
#define APP_UART_ENABLED 1
// <o> APP_UART_DRIVER_INSTANCE  - UART instance used
// <0=> 0
#ifndef APP_UART_DRIVER_INSTANCE
#define APP_UART_DRIVER_INSTANCE 0
#ifndef NRF_LOG_BACKEND_RTT_ENABLED
#define NRF_LOG_BACKEND_RTT_ENABLED 1
#ifndef NRF_LOG_BACKEND_UART_ENABLED
#define NRF_LOG_BACKEND_UART_ENABLED 0
4,增加相关的驱动文件
app_fifo.c  ,app_uart_fifo.c  这两个文件在libraries文件夹下,找找。
5,修改驱动文件的头文件路径
$PROJ_DIR$\..\..\..\..\..\..\components\libraries\fifo
$PROJ_DIR$\..\..\..\..\..\..\components\libraries\uart
编译下载固件即可。管脚可以自行修改。
作者:saver_26
来源:CSDN
原文:blog.csdn.net/.../84526754
版权声明:本文为博主原创文章,转载请附上博文链接!
