I tried to find info on how to print float values in Segger windows application, no luck. Of course my question is how do i printf() float values on debug terminal in segger.
Thanks
Thanks
Try adding -u _printf_float in the linking flags.
I found the answer on the forum after posting here. Anyways you need to go to
Project options -->Select Common Configuration -->Code -->Prinf/Scanf now change it here to Float supported.
Ref:
https://devzone.nordicsemi.com/f/nordic-q-a/30535/nrf52-printf-float-in-ses/120908#120908
I am sorry, for windows application where do I have to add that line?
That depends on your development environment. If e.g. using arm gcc and makefiles, you will have to change this in your projects makefile. I don't know exactly how projects in the latests SDK is structured, but this is what i had to to in a/some previous version(s) when i had the same issue as you.
OK! Noted and Thanks for the reply
