Trouble with transition to gcc
SDK 12.3
nrf51 DK
ARMGCC
Windows 10
I'm trying to switch to gcc. I use 4.9 2015q3 version as recommended.
I have a trouble with simple blank blinky project (nRF5_SDK_12.3.0_d7731ad\examples\peripheral\blinky\pca10028\blank\armgcc).
I make hex with make utility, prog it with nrfjprog, but it  doesn't work. nrf51422_xxac.hex
If I prog (also via nrfjprog) precompile hex file from nRF5_SDK_12.3.0_d7731ad\examples\peripheral\blinky\hex it works well. blinky_pca10028.hex
  • HI ArtG89,
    I flashed the attached hex file( nrf51422_xxac.hex) to a nRF51 DK(PCA10028) using nrfjprog and it worked fine on my end.
    I used the following nrfjprog command:
    nrfjprog -f nrf51 --program nrf51422_xxac.hex --chiperase --reset
    which gave the following output
    Parsing hex file.
    Erasing user available code and UICR flash areas.
    Applying system reset.
    Checking that the area to write is not protected.
    Programming device.
    Run.
    and LED1-3 is blinking.
    Best regards
    Bjørn
