I am using SDK 15.0 on a custom board using nRF52840. Softdevice is 6.0.0. Coding with SES.
I am investigating and trying to fix the infamous IOS caching of characteristics problem where the IOS bluetooth stack doesn't refresh and so the correct characteristics are not shown.
As part of this I am ensuring that the service changed characteristic is showing in the generic attribute service in both normal and dfu mode. I am also running:
err_code = sd_ble_gatts_service_changed( m_conn_handle, m_flex_service.svc_h, 0xFFFF);
on connection to cause the indication.
Currently I have the issue that the DFU mode service is not showing the service changed characteristic. I have stepped through the code and it appears to be enabling it in the default configuration.
Questions:
1) What do I need to do to get the service changed characteristic showing up under dfu mode?
2) Do I need the service changed characteristic in dfu mode to get the IOS bluetooth stack to update?
3) Do I just need the service changed characteristic or do I need both it and to call the sd_ble_gatts_service_changed function?
4) I am currently passing the service handle of one of my services into the sd_ble_gatts_service_changed function and 0xFFFF. Is that correct or do I need a different service handle or one call for each of my services?
Many thanks in advance
Paul
