garbage collection
I need to run gc because I get rc =FDS_ERR_NO_SPACE_IN_FLASH.
So I run gc simple as written in https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_fds_functionality.html?cp=5_1_3_55_1_2#lib_fds_functionality_gc
I just write this
rc = fds_record_update(&record_desc, &record);
if(rc == FDS_ERR_NO_SPACE_IN_FLASH) // no space in the FLASH
  ret_code_t rc = fds_gc();// try to do garbage collection
  if (rc != FDS_SUCCESS)
   /* error handle */
But just when I do the fds_gc() I get hard fault.
What do I miss here?
Bar.
  • Hi Bar
    Something like this function should suffice (This function uses the peer manager):
     case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
    Simon
  • thanks Simon.
    But what active it?
    I1. which action trigger this case?
    If written to the FLASH trigger this function it will be too late, because I can't make the writing again.
    2. Where I include (init) this handler in my program ?
    3. What is the difference, between my written and this one?
    4. What can I do with the retry? if I still do fds_gc(); I can endup with endless loop?
    Bar.
  • I use this part
    // Retry.
    But still go to hard fault when use it .
    Is there a stack size or any pre init for the gc that I miss?
    Bar.
  • Hi Bar
    How exactly do you trigger the gc? Do you get any kind of error code so we can see what exactly goes wrong? The fds_gc() function is implemented in the ble_app_gatts_c example, so you could look at that and see if you understand more. You also have to make sure that fds.c and fds.h is included in your project.
    Simon
  • Hello Simon.
    I trigger the gc when I get FDS_ERR_NO_SPACE_IN_FLASH.
    I don't get any error when go into the gc itself until I get to gc_execute(uint32_t prev_ret) and then with no ERROR it go to hardfault.
    Maybe it concern the size of the virtual FLASH I give? I read some issue about it and I see all use peer management also it must use for the ble. I take an example of using peer management, and I try to implement it in my work also I need to add a lot of files because I don't use it for ble purpose.  Do you see it will help use the peer or I can do it without this? I will look aty the example you take about and see if I can find something I forget.
    Bar.
