garbage collection
I need to run gc because I get rc =FDS_ERR_NO_SPACE_IN_FLASH.
So I run gc simple as written in https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_fds_functionality.html?cp=5_1_3_55_1_2#lib_fds_functionality_gc
I just write this
rc = fds_record_update(&record_desc, &record);
if(rc == FDS_ERR_NO_SPACE_IN_FLASH) // no space in the FLASH
  ret_code_t rc = fds_gc();// try to do garbage collection
  if (rc != FDS_SUCCESS)
   /* error handle */
But just when I do the fds_gc() I get hard fault.
What do I miss here?
Bar.
  • I did anther test.
    Every time before and after fds_gc I active fds_stat(&stat); , and compare the statistic in state.
    I actrive the function in this way:
     rc = fds_stat(&stat); // TEST TEST TEST to see if gc work
     rc = fds_gc();
    When it wasn't on the limit of the FLASH the gc work fine and if there was dirty record it remove them.
    But when I get to rc == FDS_ERR_NO_SPACE_IN_FLASH and try the same I get before the gc this statistic:
    pages_available= 0x3
    open_records= 0x0
    valid_records= 0x56
    dirty_records=0x55
    words_used= 0x07FA
    largest_contig=0x4
    freeable_words=0x03F5
    corruption=false
    But there it go to hardfault.
    The number looks logical because for ease record I update it in the past, and there is still free words.
    Is this give any clue?
    Bar.
  • Hi Bar
    Sorry, but I'll need you to describe what exactly your project is supposed to do and how to set it up correctly, as it will take an immense amount of time to get into it as is. Step by step would be best. And still, tell me if you want this case set to private!
    Simon
