I am using NRF51822 pca10028 UART ble example ,
I need to give provision to change the name of the device after pairing and reset the device so that it starts advertising with the name provided by the user,
Thank you
Thank you
This can be done in the following way: You have update the device's name over UART, store the new name in flash, and set the new device name after reset.
The new device name is not automatically written to flash, it means that upon a reset, the device will have the original device name. If you want to store and re-store the updated device name upon a reset, you will have to do that manually using fstorage.
There are many threads discussing this topic already on the forum, I would suggest you use the search function to examples on how to do it :)
Hi Mttrinh,
I have tried the pstorage example from the Git LAB and got to know how to access the Flash memory .But now can i change the name of the BLE by taking the input from the BLEUART and handle the name change in the nus_data_handler() or is there any option to change the BLE name
It would be helpful if i get a example or document or usefullthread regarding the same .
Thankyou,
Nitin
Nitin Kumar said:i change the name of the BLE by taking the input from the BLEUART and handle the name change in the nus_data_handler()
Yes, that is correct :) you can change the name with this function sd_ble_gap_device_name_set(..).
Hi Mttrinh,
I tried using pstorage ,got the data in nus_data_handler() and used sd_ble_gap_device_name_set () passed the value and gave a soft reset sd_nvic_SystemReset() .
The name change works or reflects only in NRF toolbox UART app but when i search in normal BLE Scanner the name is not updated .
uint32_t err_code;
bool erase_bonds;
uint8_t start_string[] = START_STRING;
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
ble_stack_init();
device_manager_init(erase_bonds);
pstorage_test_store_and_update();
// printf("pstorage load blocks 0 \r\n");
pstorage_load(dest_data_0, &block_0_handle, 16, 0); //Read from flash, only one block is allowed for each pstorage_load command
nrf_delay_ms(2000);
printf(" Data loaded from block 0: %s\r\n", dest_data_0);
gap_params_init();
services_init();
advertising_init();
conn_params_init();
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
printf("%s",start_string);
// DATA_NAME=dest_data_0;
// Enter main loop.
for (;;)
power_manage();
printf("\n\rtime0=%lld",time0);
nrf_delay_ms(1000);
time0++;
static void example_cb_handler(pstorage_handle_t * handle,
uint8_t op_code,
uint32_t result,
uint8_t * p_data,
uint32_t data_len)
if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; } //If we are waiting for this callback, clear the wait flag.
switch(op_code)
case PSTORAGE_LOAD_OP_CODE:
if (result == NRF_SUCCESS)
printf("pstorage LOAD callback received \r\n");
bsp_indication_set(BSP_INDICATE_ALERT_0);
printf("pstorage LOAD ERROR callback received \r\n");
bsp_indication_set(BSP_INDICATE_RCV_ERROR);
case PSTORAGE_STORE_OP_CODE:
printf("pstorage STORE callback received \r\n");
bsp_indication_set(BSP_INDICATE_ALERT_1);
printf("pstorage STORE ERROR callback received \r\n");
case PSTORAGE_UPDATE_OP_CODE:
printf("pstorage UPDATE callback received \r\n");
bsp_indication_set(BSP_INDICATE_ALERT_2);
printf("pstorage UPDATE ERROR callback received \r\n");
case PSTORAGE_CLEAR_OP_CODE:
printf("pstorage1 CLEAR callback received \r\n");
bsp_indication_set(BSP_INDICATE_ALERT_3);
printf("pstorage 2CLEAR ERROR callback received \r\n");
static void pstorage_test_store_and_update(void)
pstorage_module_param_t param;
retval = pstorage_init();
if(retval != NRF_SUCCESS)
bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
param.block_size = 16; //Select block size of 16 bytes
param.block_count = 4; //Select 10 blocks, total of 160 bytes
param.cb = example_cb_handler; //Set the pstorage callback handler
nrf_delay_ms(1000);
printf("\r\n\r\npstorage initializing ... \r\n");
retval = pstorage_register(¶m, &handle);
if (retval != NRF_SUCCESS)
pstorage_block_identifier_get(&handle, 0, &block_0_handle);
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
if(p_data[0] == 'N')
for (int a = 1; a < length; a++)
source_data_0[a] =p_data[a] ;
// while(app_uart_put(p_data[a]) != NRF_SUCCESS);
printf("pstorage clear 48 bytes from block 0 \r\n");
retval = pstorage_clear(&block_0_handle, 48);
if(retval != NRF_SUCCESS) { bsp_indication_set(BSP_INDICATE_RCV_ERROR); }
printf("pstorage store into block 0\r\n Data written into block 0: %s\r\n", source_data_0);
pstorage_store(&block_0_handle, source_data_0, 16, 0); //Write to flash
nrf_delay_ms(2000);
printf("pstorage wait for block 0 store to complete ... \r\n");
while(pstorage_wait_flag) { power_manage(); } //Sleep until store operation is finished.
nrf_delay_ms(2000);
nrf_delay_ms(3000);
if(p_data[0] == 'R')
app_uart_flush();
printf("Resetcause0x01");
nrf_delay_ms(3000);
sd_nvic_SystemReset();
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *) dest_data_0,
sizeof(dest_data_0));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
normal BLE Scanner
What do you mean by that? What is, "normal"?!
Note that the OS may be "caching" the old name - so you may have to turn the BT off & on again to clear the cache ...
