#define SAMPLES_IN_BUFFER 5
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
ret_code_t err_code;
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 11);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
// i tried stop_adc() here but its the same resulut
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
stop_adc();
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =
.resistor_p = NRF_SAADC_RESISTOR_DISABLED, \
.resistor_n = NRF_SAADC_RESISTOR_DISABLED, \
.gain = NRF_SAADC_GAIN1_4, \
.reference = NRF_SAADC_REFERENCE_INTERNAL , \
.acq_time = NRF_SAADC_ACQTIME_10US, \
.mode = NRF_SAADC_MODE_SINGLE_ENDED, \
.burst = NRF_SAADC_BURST_DISABLED, \
.pin_p = NRF_SAADC_INPUT_AIN1, \
.pin_n = NRF_SAADC_INPUT_DISABLED \
nrf_drv_saadc_config_t saadc_config;
//Configure SAADC
saadc_config.low_power_mode = true; //Enable low power mode.
saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT; //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=2048 (when input voltage is 3.6V for channel gain setting of 1/6).
saadc_config.interrupt_priority = _PRIO_APP_LOW; //Set SAADC interrupt to low priority.
saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
err_code = nrf_drv_saadc_channel_init(1, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
void start_adc
saadc_init();
saadc_sampling_event_init();
void stop_adc()
nrf_drv_timer_disable(&m_timer);
nrfx_timer_uninit(&m_timer);
ret_code_t err_code = nrf_drv_ppi_channel_disable(m_ppi_channel);
err_code = nrf_drv_ppi_uninit();
nrfx_saadc_uninit();
err_code = nrf_drv_saadc_channel_uninit(1);
I am using nrf52840 with custom board, sdk 15 and and softdevice 6.0.0. I modified saadc example to sample SAADC value once and stop it in saadc_callback. Everything works great, but when I start SAADC and measure the current, it consumes 2 extra mA which means SAADC is not stopped because this happens only with SAADC start and only software reset can stop it. I used nrfx_saadc_sample() and nrf_drv_saadc_abort instead of timer but it does not stop as well.
I tried all the answers for related problems, but it did not help.
