I wanted to build a single shot timer using the nrf_timer library. I went into the library code and I couldn't understand some of the enumeration due to some lack of documentation. In the example simple_timer application, the single shot timer uses nrf_drv_timer_extended_compare instead of nrf_drv_timer_compare. Also it uses the NRF_TIMER_SHORT_COMPARE0_STOP_MASK.
Does STOP mean that the timer stops or does it keep counting under the hood?
Also does nrfx_timer_disable() mean that the counting stops in the physical timer or the software abstraction of the timer?
Can you give me a brief explanation of STOP vs CLEAR as well as COMPARE(x) types? Does CLEAR/STOP indicate that it reloads the timer thus making it a normal repeating timer?
Moreover, can you give me a simple way of implementing a single shot timer using the library and give me a way to reload it later and start again as I need?
Thanks!
