I am working on a custom PCB with NRF9160.
I have modified nrf9160 uart sample to add UART_1 and enable SPI_3 and everything is working fine.
Now I need to include I2C_3 but SES will not open project if I add I2C_3 to 'prj.config' Please see output below:
Loading solution uart.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=C:/NRF91SDK/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb/8 2018-q4-major -BC:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/build -HC:/NRF91SDK/ncs/nrf/samples/nrf9160/uart -DDTC_OVERLAY_FILE=C:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/nrf9160_pca10090.overlay
-- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.2", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090
Zephyr version: 1.13.99
Parsing Kconfig tree in C:/nRF91SDK/ncs/zephyr/Kconfig
Loading C:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/build/zephyr/.config as base
-- Loading C:/NRF91SDK/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying C:/nRF91SDK/ncs/zephyr/dts/common/common.dts
-- Overlaying C:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/nrf9160_pca10090.overlay
nrf9160_pca10090.dts_compiled: Warning (unit_address_format): /soc/adc@0x4000e000: unit name should not have leading "0x"
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/i2c@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/i2c@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/i2c@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/i2c@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40008000: duplicate unit-address (also used in node /soc/spi@40008000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@40009000: duplicate unit-address (also used in node /soc/spi@40009000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000a000: duplicate unit-address (also used in node /soc/spi@4000a000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/uart@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/i2c@4000b000: duplicate unit-address (also used in node /soc/spi@4000b000)
nrf9160_pca10090.dts_compiled: Warning (unique_unit_address): /soc/clock@40005000: duplicate unit-address (also used in node /soc/power@40005000)
-- Cache files will be written to: C:\Users\ibrah\AppData\Local/.cache/zephyr
-- The C compiler identification is GNU 8.2.1
-- The CXX compiler identification is GNU 8.2.1
-- Found assembler: C:/gnuarmemb/8 2018-q4-major/bin/arm-none-eabi-gcc.exe
-- Performing Test toolchain_is_ok
-- Performing Test toolchain_is_ok - Success
CMake Warning (dev) at C:/NRF91SDK/ncs/zephyr/cmake/extensions.cmake:837 (target_link_libraries):
Policy CMP0079 is not set: target_link_libraries allows use with targets in
other directories. Run "cmake --help-policy CMP0079" for policy details.
Use the cmake_policy command to set the policy and suppress this warning.
Target
zephyr_interface
is not created in this directory. For compatibility with older versions of
CMake, link library
-mabi=aapcs
will be looked up in the directory in which the target was created rather
than in this calling directory.
C:/NRF91SDK/ncs/zephyr/cmake/extensions.cmake:1055 (target_link_libraries_ifdef)
C:/NRF91SDK/ncs/zephyr/cmake/extensions.cmake:115 (target_ld_options)
C:/NRF91SDK/ncs/zephyr/arch/arm/CMakeLists.txt:20 (zephyr_ld_options)
This warning is for project developers. Use -Wno-dev to suppress it.
Target
zephyr_interface
CMake, link library
-march=armv8-m.main+dsp
CMake Error at C:/NRF91SDK/ncs/zephyr/CMakeLists.txt:678 (message):
The Zephyr library 'drivers__i2c' was created without source files. Empty
(non-imported) libraries are not supported. Either make sure that the
library has the sources it should have, or make sure it is not created when
it has no source files.
See also "C:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/build/CMakeFiles/CMakeOutput.log".
See also "C:/NRF91SDK/ncs/nrf/samples/nrf9160/uart/build/CMakeFiles/CMakeError.log".
Project load failed
Reported error: solution load command failed (1)
my prj.config:
CONFIG_SERIAL=y CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_1_NRF_UARTE=y # SPI CONFIG_SPI=y CONFIG_SPI_3=y CONFIG_SPI_3_NRF_SPIM=y CONFIG_SPI_3=y CONFIG_SPI_NRFX=y # Enable I2C CONFIG_I2C=y CONFIG_I2C_3=y CONFIG_I2C_3_NRF_TWIM=y CONFIG_I2C_NRFX=y CONFIG_I2C_INIT_PRIORITY=60
I tried using i2c_scanner sample and that worked but uart sample doesn't
Please help
Thank you
