Low Power Consumption nRF8001
Hi guys,
Do you have any suggestions on how I can lower the power consumption. I am currently connecting - sending data - disconnecting.
I have the following set the parameters as: Min/Max Interval = 15/15, Slave Latency = 0, Timeout = 3000 ms.
Thanks!
  • For the previous graph, I was using a multimeter that gets the average current.
    Also, I tried varying and increasing the slave latency, but it seemed that the current consumption was much higher. I was expecting it to be lower. Is this what's expected?
    Connection Interval (15ms/15ms)
      Slave Latency
    Cycle Time 0 10 20
    10 s 0.19414685 0.190959527 0.22098695
    30 s 0.056611663 0.064026546 0.06247249
  • It's not possible to measure the current properly using a multimeter while the radio is active as the multimeter is to slow. For current measurements during sleep it is ok. For accurate current measurements you need a dcdc power analyser, or similar. Our PPK is also an option.
    I am not sure what your table is showing. The current consumption calculator will give an estimate based on your use case.
  • I see, thanks for the suggestion. I will try that when I measure again.
    As for the table, it shows the average current (mA)  consumption when I set slave latency = 10 and connection interval min=15ms max=15ms and I measure 0.194mA. I increased the slave latency to 10 and 20 and you can see the average current consumption accordingly.
    As mentioned in my previous replies, I seem to be getting higher average current consumption (offset of about ~100uA) compared to the current consumption calculator.
  • Are you sure you are keeping the input pins of the nRF8001 at a defined state all the time? If the application mcu leaves one of those floating it would typically draw around 100µA.
