I am using nRF52832, SDK_15.3.0, S132 SoftDevice and Segger for flash the image. I am using ‘ble_app_blinky’.
I have gone through “Application Timer” tutorial.
I have few queries.
1) Using “Application Timer module” how many max timers / handlers can be executed at a time with APP_TIMER_MODE_REPEATED. At application level I need 5 timers. Since RTC1 has CC[0..3] whether I can use only 4 at a time.
- a) Whether APP_TIMER_CONFIG_OP_QUEUE_SIZE is for that purpose only ?
2) I want to sleep & wakeup periodically for every 30 minutes. For this I need to change PRESCALER. To my understanding there will be only one prescaler for entire timer module. So if I change, will there be any impact on existing timers and SoftDevice (Not sure whether SoftDevice uses Application Timer).
3) I want to stop LED after 10 blink automatically. In this case with some conditions whether can I call app_timer_stop() within same handler (repeated_timer_handler()).
static void repeated_timer_handler(void * p_context)
err_code = app_timer_stop(m_repeated_timer_id);
4) Whether handler will execute in Interrupt context. I want to read data over TWI and write data into Flash. Whether all there can be called within timer handler.
static void repeated_timer_handler_1(void * p_context)
// Read sensor data.
// Write data into Flash
nrf_fstorage_write( ... );
Thanks & Regards
Vishnu Beema
