SAADC SAMPLING ISSUE
I want to get Battery ADC Value.
So, I simply used nrf_drv_saadc_convert()
At first I thought it was the right value,
Later, I found out the wrong value.
If you supply 1.5v, the value should be over 400, but less than 100.
(used battery service)
CODE :
// ADC setting
static nrf_saadc_value_t m_battery;
    //ret_code_t err_code;
	//err_code =  nrf_drv_saadc_sample_convert(0, &m_battery);
	//APP_ERROR_CHECK(err_code);
static void bat_timeout_handler(void * p_context)
	UNUSED_PARAMETER(p_context);
	// get ADV value
	// (%)percent change formula
	uint8_t percent = ((m_battery-MIN_ADC)/DIF_ADC)*100;
	if(percent >= 100)
		percent = 100;
	NRF_LOG_INFO("ADC : %d%",m_battery);
	NRF_LOG_INFO("battery : %d%",percent);
	// send (%)percent value
	err_code = ble_bas_battery_level_update(&m_bas, percent, BLE_CONN_HANDLE_ALL);
	if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != NRF_ERROR_BUSY) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
        APP_ERROR_HANDLER(err_code);
static void saadc_init(void)
#if TEST
	nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(ARDUINO_A0_PIN);
#else
	// SAADC configuration struct and pin setting
	nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_ADC_IN);
	// SAADC struct init and register SAADC evnet handler
	err_code = nrf_drv_saadc_init(NULL, saadc_callback);
	// SAADC channel init
	err_code = nrf_drv_saadc_channel_init(0, &channel_config);
static void application_timers_start(void)
	err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL/*1s*/, NULL);
Let me know what's wrong.
Thank you.
<softdevice : 6.1.1, SDK : 15.2.0, nRF52-DK>
